VMware VMFS datastores (deb/2.7/UI)
Five questions you may have:
  1. How do I list the VMFS datastores on a machine?
  2. How do I view a specific datastore on a machine?
  3. How do I create a new datastore?
  4. How do I edit a datastore?
  5. How do I delete a datastore?
Listing VMFS datastores
        "human_size": "45.8 GB",
        "filesystem": {
            "fstype": "vmfs6",
        "name": "datastore1",
        "system_id": "4qxaga",
        "devices": [
                "size": 35026632704,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                    "mount_point": null,
                    "mount_options": null
                "type": "partition",
                "device_id": 5,
                "id": 71,
                "size": 10729029632,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 6,
                "id": 77,
        "id": 17,
        "size": 45755662336,
Viewing a specific datastore
    "system_id": "b66fn6",
    "id": 18,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "2.8 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
    "size": 2814377984,
Creating a new VMFS Datastore
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "device_id": 1,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "id": 80,
    "name": "datastore42",
    "filesystem": {
        "fstype": "vmfs6",
    "id": 19,
    "size": 2814377984,
Edit an existing VMFS Datastore
    "id": 19,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "13.5 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
            "bootable": false,
            "tags": [],
            "id": 86,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 2,
    "size": 13543407616,
Deleting a VMFS Datastore
