2.7 | 2.8 | 2.9 | 3.0 | |
MAAS VM hosts allow for the dynamic composition of nodes from a pool of available hardware resources (e.g. disk space, memory, cores). You can create virtual machines (VMs) as needed within the limits of your resources, without concern for physical hardware. MAAS currently supports VM hosts and VMs created via libvirt. MAAS also supports LXD VMs and VM hosts as a Beta feature.
Nine questions you may have:
- What is a VM host?
- Which VM host should I use: LXD or KVM?
- How do I make LXD available for hosting?
- How do I add a VM host?
- How do I see resources for a specific NUMA node?
- How do I see resources for NUMA-node-bearing VM hosts?
- How do I see the alignment between VM host interfaces and NUMA nodes?
- How do I configure and use hugepages on my VMs?
VM hosts are particularly useful for Juju integration, allowing for dynamic allocation of VMs with custom interface constraints. Alternatively, if you would like to use MAAS to manage a collection of VMs, the robust web UI allows you to easily create and manage VMs, logically grouped by VM host. Six conspicuous features include:
- Juju integration
- At-a-glance visual tools for easy resource management
- Set overcommit ratios for physical resources such as CPU and RAM
- Assign VMs to resource pools to segregate your VMs into logical groupings
- Track VM host storage pool usage and assign default storage pools
- Create VMs on multiple networks, specified by space, subnet, VLAN, or IP address
This section will lead you through the creation, usage, and management of VM hosts. Note that, as LXD VM hosts are still in Beta, some screen terminology has not yet been changed to reflect “VM host” instead of “KVM.” You will still use the “KVM” tab on the top of the MAAS dashboard to reach the VM host functionality, and you may see buttons which refer to “Add KVM,” for example, instead of “Add VM host.” Rest assured that the Beta LXD VM host functionality is fully available through these channels.
What is a VM host?
Simply put, a VM host is a machine which is designated to run virtual machines (VMs). A VM host divides its resources (CPU cores, RAM, storage) among the number of VMs you want to create, based on choices that you make when creating each VM. It is also possible to overcommit resources – that is, use more resources than the VM host actually has available – as long as you use the VMs carefully. Once MAAS has enlisted, commissioned, and acquired a newly-added machine, you can deploy it as a VM host.
LXD VM host (Beta) vs. libvirt
Libvirt KVMs and LXD VMs are both based on the same underlying virtualisation technology, QEMU. Unlike libvirt KVMs, though, LXD VMs can be managed without requiring SSH access to the VM host. LXD are remotely accessed via secure HTTP transport, which provides better security for LXD-based VMs. In addition, LXD has a better API, and is part of a much larger constellation of enterprise software, offering a wider range of future features and use cases.
VMs and NUMA
MAAS provides extensive optimisation tools for using NUMA with virtual machines. Earlier versions of MAAS guarantee that machines are assigned to a single NUMA node that contains all the machine’s resources. As of 2.9, MAAS now allows you to see how many VMs are allocated to each NUMA node, along with the allocations of cores, storage, and memory. You can quickly spot a VM running in multiple NUMA nodes, and optimise accordingly, with instant updates on pinning and allocations. You can also tell which VMs are currently running.
In addition, you can get a bird’s-eye view of network configuration:
- You can see which VM NIC/bond is connected to which NUMA node.
- You can tell when a NIC is connected to a different NUMA node.
- You can tell if one of multiple NICs is not in the correct node.
- You can confirm the subnet and space connecting to a VM.
- You can confirm that a VM has the desired network properties, such as latency and throughput.
- You can identify NICs that support SR-IOV and tell how many VFs are available.
MAAS also shows hugepages information (if they are in use) and prevents overcommit when using them. Hugepages essentially allow a much larger memory cache associated with the core. This obviously reduces the number of times a core has to access memory, but because the core must swap entire hugepages, optimising usage of them can be complex. MAAS helps you create these optimisations by giving you a discrete view of hugepages associated with your VM, helping you decide whether you need to use them or not.
Support for NUMA, SR-IOV, and hugepages
VM host management has been redesigned to support NUMA/SR-IOV configurations and hugepages from the API/CLI. Users can:
- See resources per NUMA node.
- See resources for VM hosts bearing NUMA nodes.
- See the alignment between VM host interfaces and NUMA nodes.
- Configure and use hugepages.
This section explains how to access this new functionality.
Examine NUMA node resources
You can examine the resources of a NUMA node with the MAAS CLI. A very basic way to do so is to enter the following command for a configured VM:
In the resulting JSON output, look for the array entry numanode_set
, which will show the NUMA details for that specific VM:
"numanode_set": [
"index": 0,
"memory": 16384,
"cores": [
0,
2,
1,
3,
"hugepages_set": [
"page_size": 2097152,
"total": 0
Examine resources for NUMA-node-bearing VM hosts
With the MAAS CLI, you can get an overview of resource usage for an LXD host that’s running NUMA VMs with the following command:
maas $PROFILE virtual-machines read
Currently, the API does not give you an aggregated usage, as provided in the UI; hence you’ll have to look at the VMs and sum up the usage data yourself. You can see a list of pinned cores via this method, and we do show alignment of machines and NUMA nodes.
Examine the alignment between VM host interfaces and NUMA nodes
To see an alignment of VM host interfaces and NUMA nodes via the CLI, you can use the command mentioned above:
and focus on the interface_block
section in the resulting JSON. This will give you the alignment information you’re seeking.
Configure and use hugepages on my VMs
Configuring hugepages for VM use consists of two steps:
- Creating a tag which includes a kernel option to use hugepages.
- Composing a VM backed with hugepages, tagged with the newly-created tag.
Here are the specific commands:
maas $PROFILE tags create name=use-hugepages kernel_opts=default_hugepagesz=1G hugepages=20"
maas $PROFILE vm-host compose $VM_HOST_ID pinned_cores=$CORE_NUMBER hugepages_backed=true
Make LXD available for VM hosting (Beta)
Assuming that you want to use LXD VM hosts – currently a Beta feature – you need to install the correct version of LXD. Prior to the release of Ubuntu 20.04 LXD was installed using Debian packages. The Debian packaged version of LXD is too old to use with MAAS. If this is the case, you’ll need to remove the LXD Debian packages and install the Snap version. Note that you cannot install both Debian and snap versions, as this creates a conflict.
Reading package lists... Done
Building dependency tree
$ sudo apt-get autoremove -y
$ sudo snap install lxd
Refreshing LXD on 20.04
$ sudo snap refresh
All snaps up to date.
Initialise LXD prior to use
Once LXD is installed it needs to be configured with lxd init
before first use:
$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: no
- MAAS does not support LXD clusters in this Beta version. -
Name of the storage back-end to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir
- Beta testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk. -
Would you like to connect to a MAAS server? (yes/no) [default=no]: no
- When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing in this Beta version. -
- The bridge LXD creates is isolated and not managed by MAAS. If this bridge is used, you would be able to add the LXD VM host and compose virtual machines, but commissioning, deploying, and any other MAAS action which uses the network will fail – soyes
is the correct answer here. -
- br0 is the name of the bridge the user configured (see sections above) which is connected to a MAAS-managed network. -
Trust password for new clients:
- This is the password the user will enter when connecting with MAAS.
Again:
