How to use MAAS in an air-gapped environment (snap/3.0/CLI)
Many MAAS users maintain their data centres in an air-gapped environment that does not have an external Internet connection. MAAS runs well in this configuration, though keeping MAAS supplied with updates and images requires a bit of extra effort.
Five questions you may have:
Using the snap proxy
Using local package repos
Local image mirrors
  1. Use user_data.
Creating a transparent proxy
