Troubleshooting (deb/3.0/CLI)
Nodes hang on “Commissioning”
Possible Cause: Timing issues
Node deployment fails
to apt keyring
line 540, in add_apt_key_raw
    cmd=args)
Exit code: 2
Reason: -
Stdout: ''
Nodes fail to PXE boot
Possible Cause: DHCP conflict
Can’t log in to node
Can’t find MAAS web UI
Backdoor image login
Extract the cloud image
For example:
mkdir xenial
Generate password hash
Rebuild SquashFS image
[=======]  2516/26975   9%
Use the custom image
mv squashfs squashfs_original
chown maas:maas squashfs
