How to interpret testing logs
This page explains how to interpret MAAS test logs.
smartctl-validate
Provided by Canonical, smartctl-validate uses the smartmontools kit to ensure your disk’s integrity. A successful run looks something like this:
Serial Number:    QM00001
Firmware Version: 2.5+
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Unavailable
Write cache is:   Enabled
ATA Security is:  Unavailable
Wt Cache Reorder: Unavailable
General SMART Values:
					was completed without error.
					been run.
					command.
					Self-test supported.
					power-saving mode.
Short self-test routine
Extended self-test routine
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SCT Commands not supported
smartctl output
The smartctl output can be dense, so let’s decode each section.
Header
This part provides metadata about smartctl itself, such as the version you’re running and the copyright information. It helps in ensuring you’re using an updated toolset.
Device specifics
Here, you see details about the hard disk model, its serial number, firmware, storage capacity, and the size of its data sectors. These give you an overall snapshot of your drive’s hardware specifics.
SMART support
This section confirms whether SMART capabilities are available and enabled. AAM (Automatic Acoustic Management) and APM (Advanced Power Management) are also mentioned, but they are unavailable in this example.
Timestamp/ATA
The timestamp informs you when the test was conducted. The ATA Version gives details about the ATA protocol that your drive supports.
SMART attributes
The lengthy section on SMART attributes provides specific metrics about your drive’s health. Each attribute—like Raw_Read_Error_Rate or Reallocated_Sector_Ct—has its numerical values and flags. These serve as indicators for disk performance or upcoming failures. For example, Reallocated_Sector_Ct refers to the number of sectors that have been flagged as faulty and reallocated.
Error logs/other
No Errors Logged
If there were issues during the SMART data collection or previous tests, they would be listed here.
Command sets
The absence or presence of SCT (SMART Command Transport) commands could influence the kinds of tests and operations you can perform on the disk.
Unsupported features
Finally, these lines indicate features that are not supported by the disk. It’s useful to know these limitations for advanced troubleshooting.
The output of smartctl can help you understand your disk’s status, potentially diagnosing issues before they become problems.
Advanced insights
MAAS allows you to scrutinise individual logs. Navigate to a machine of interest and choose the ‘Hardware tests’ page. There, you’ll see a ‘Log view’ link in the ‘Results’ column for each test. Clicking this grants you access to detailed outputs, enabling more sophisticated diagnostics.
