Resource pools (deb/3.0/CLI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
Seven questions you may have:
  1. How can I create a resource pool?
  2. How can I list available resource pools?
  3. How can I list a single resource pool?
  4. How can I update a resource pool?
  5. How can I delete a resource pool?
  6. How can I add a machine to a resource pool?
  7. How can I get started with MAAS CLI?
Creating a resource pool
List available resource pools
List a single resource pool
Update a resource pool
Delete a resource pool
