Proxy (snap/2.9/CLI)
2.7 2.8 2.9
  1. internal proxy (default)
  2. external proxy
  3. no proxy
Two questions you may have:
  1. How and why should I create an internal proxy?
  2. How and why should I create an external proxy?
Internal proxy (MAAS proxy)
MAAS manages its proxy. So although the active configuration, located in file /var/snap/maas/current/proxy, can be inspected, it is not to be hand-edited. The proxy is automatically installed with the MAAS snap.
Configure proxy
Enabling and disabling proxying, in general, is done via a boolean option (‘true’ or ‘false’). The following command will disable proxying completely:
maas $PROFILE maas set-config name=enable_http_proxy value=false
To set an external proxy, ensure proxying is enabled (see above) and then define it:
maas $PROFILE maas set-config name=http_proxy value=$EXTERNAL_PROXY
For example,
maas $PROFILE maas set-config name=enable_http_proxy value=true
maas $PROFILE maas set-config name=http_proxy value=http://squid.example.com:3128/
Enabling and disabling proxying per subnet is done via a boolean option (‘true’ or ‘false’). Here is how you can disable proxying on a per-subnet basis:
maas $PROFILE subnet update $SUBNET_CIDR allow_proxy=false
For example,
maas $PROFILE subnet update 192.168.0.0/22 allow_proxy=false
