Power management (deb/2.8/CLI)
Four questions you may have:
  1. How do I configure a machine’s power type?
  2. Show me a catalogue of power parameters, by type.
  3. Can you give me an example of the virsh power type?
  4. Which BMC drivers are supported?
HP Moonshot - iLO4 (IPMI)
Form field Description Required
Power address IP address of unit Required
Power user Username to login Optional
Power password Password to access unit Optional
Power hardware address Hardware address of unit Required
HP Moonshot - iLO Chassis Manager
IP for MSCM CLI API IP address of unit Required
MSCM CLI API user Username to login Optional
MSCM CLI API password Password to access unit Optional
Node ID cXnY Required
- where X = cartridge number
Y = node number
Microsoft OCS - Chassis Manager
Power port Port where unit is attached Optional
Blade ID Blade ID (usu. 1-24) Required
OpenStack Nova
Host UUID Host UUID Required
Tenant name Tenant name Required
Username Username to login Required
Password Password to access unit Required
Auth URL URL to access unit Required
OpenBMC Power Driver
OpenBMC address IP address of unit Required
OpenBMC user Username to login Required
OpenBMC password Password to access unit Required
Christmann RECS-Box Power Driver
Node ID Node ID Required
Redfish
Redfish address IP address of unit Required
Redfish user Username to login Required
Redfish password Password to access unit Required
Node ID Node ID Optional
SeaMicro 15000
Form field Description Choices Required
Power control type Password to access unit IPMI Required
REST API v0.9
REST API v2.0
Cisco UCS Manager
Server UUID Server UUID Required
URL for XML API XML API URL Required
API user API user Optional
API password API password Optional
virsh - libvirt KVM
Address URL of VM Required
Password API password Optional
Virsh VM ID libvirt VM UUID Required
VMware
VM Name VM name (if UUID unknown) Optional
VM UUID VM UUID (if known) Optional
VMware IP IP address of VM Required
VMware username Username to access VM Required
VMware password Password to access VM Required
VMware API port VMware API port number Optional
VMware API protocol VMware API protocol Optional
Facebook’s Wedge
IP address IP address of unit Required
Power user Username to access unit Optional
Configure a machine’s power type
To (re)configure a machine’s power type, first find the machine’s $SYSTEM_ID with the following recipe:
maas admin machines read | jq -r '(["HOSTNAME","SIS'S"] | (., map(length*"-"))),
Next, use the MAAS CLI command maas machines... to (re)set the machine’s power type, like this:
maas $PROFILE machine update $SYSTEM_ID power_type="$POWER_TYPE"
where $POWER_TYPE can have the following values:
CLI power_type code Description
amt Intel AMT
apc American Power Conversion (APC) PDU
dli Digital Loggers, Inc. PDU
eaton Eaton PDU
hmc IBM Hardware Management Console (HMC)
lxd LXD VM
ipmi IPMI
manual Manual power configuration
moonshot HP Moonshot - iLO4 (IPMI)
mscm HP Moonshot - iLO Chassis Manager
msftocs Microsoft OCS - Chassis Manager
nova OpenStack Nova
openbmc OpenBMC Power Driver
recs_box Christmann RECS-Box Power Driver
redfish Redfish
sm15k SeaMicro 15000
ucsm Cisco UCS Manager
virsh libvirt KVM
vmware VMware
wedge Facebook’s Wedge
Note the required and optional parameters associated with each power type.
Once you’ve successfully processed the command (as indicated by a stream of JSON, headed by “Success!”), MAAS performs a power check on the machine. A successful power check is a good indication that MAAS can properly communicate with the machine, that is, it should quickly result in a power status of “Power off”. A failed attempt will return errors that should guide you to fix your power_parameters.
Power catalogue
Intel AMT
All parameters are entered as key=value, e.g., power_type=amt. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
Parameter Description Required
power_type amt Required
power_address IP address of unit Required
power_pass Password to access unit Optional
All parameters are entered as key=value, e.g., power_type=apc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type apc Required
node_outlet PDU node outlet number Required
power_on_delay outlet power ON delay Optional, default=5
All parameters are entered as key=value, e.g., power_type=dli. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type dli Required
outlet_id outlet ID Required
power_user Username to login Optional
Eaton PDU
All parameters are entered as key=value, e.g., power_type=eaton. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type eaton Required
All parameters are entered as key=value, e.g., power_type=hmc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type hmc Required
server_name HMC managed server name Required
lpar HMC logical partition of unit Required
LXD VMs
All parameters are entered as key=value, e.g., power_type=lxd. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type lxd Required
instance_name LXD container instance name Required
IPMI
All parameters are entered as key=value, e.g., power_type=ipmi. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
Parameter Description Choices Required
power_type ipmi Required
power_driver Power driver LAN [IPMI 1.5] Required
LAN_2_0 [IPMI 2.0]
power_boot_type Boot type Automatic Required
Legacy boot
EFI boot
Manual power configuration means exactly that – manually configured at the unit. The only MAAS CLI parameter is power_type=amt.
All parameters are entered as key=value, e.g., power_type=moonshot. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | moonshot` Required
power_hwaddress Hardware address of unit Required
All parameters are entered as key=value, e.g., power_type=mscm. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | mscm` Required
node_id cXnY Required
Y = node number
All parameters are entered as key=value, e.g., power_type=msftocs. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | msftocs` Required
blade_id Blade ID (usu. 1-24) Required
power_port Port where unit is attached Optional
OpenStack Nova
All parameters are entered as key=value, e.g., power_type=nova. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | nova` Required
nova_id Host UUID Required
os_tenantname Tenant name Required
os_username Username to login Required
os_password Password to access unit Required
os_authurl URL to access unit Required
All parameters are entered as key=value, e.g., power_type=openbmc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type openbmc Required
power_user Username to login Required
power_pass Password to access unit Required
All parameters are entered as key=value, e.g., power_type=recs_box. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | recs_box` Required
node_id Node ID Required
Redfish
All parameters are entered as key=value, e.g., power_type=redfish. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | redfish` Required
node_id Node ID Optional
SeaMicro 15000
All parameters are entered as key=value, e.g., power_type=sm15k. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type sm15k Required
power_control Password to access unit ipmi Required
restapi
restapi2
Cisco UCS Manager
All parameters are entered as key=value, e.g., power_type=ucsm. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type ucsm Required
uuid Server UUID Required
power_address URL for XML API Required
power_user API user Optional
power_pass API password Optional
virsh - libvirt KVM
All parameters are entered as key=value, e.g., power_type=virsh. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type virsh Required
power_id libvirt VM UUID Required
power_address URL of VM Required
VMware
All parameters are entered as key=value, e.g., power_type=vmware. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type vmware Required
power_vm_name VM name (if UUID unknown) Optional
power_uuid VM UUID (if known) Optional
power_address IP address of VM Required
power_user Username to access VM Required
power_pass Password to access VM Required
power_port VMware API port number Optional
power_protocol VMware API protocol Optional
Facebook’s Wedge
power_type wedge Required
power_user Username to access unit Optional
Consider a machine backed by a KVM, accessed via virsh. You can create a corresponding MAAS machine and set its power parameters with a command like this one:
maas admin machines create \
architecture=amd64 \
power_type=virsh \
power_parameters_power_id=f677a842-571c-4e65-adc9-11e2cf92d363 \
If successful, this will return:
Machine-readable output follows this announcement. The JSON generated by this command is shown in the detail block.
MAAS command JSON response ``` { "storage": 0.0, "tag_names": [], "special_filesystems": [], "memory": 0, "boot_disk": null, "virtualblockdevice_set": [], "hardware_info": { "system_vendor": "Unknown", "system_product": "Unknown", "system_family": "Unknown", "system_version": "Unknown", "system_sku": "Unknown", "system_serial": "Unknown", "cpu_model": "Unknown", "mainboard_vendor": "Unknown", "mainboard_product": "Unknown", "mainboard_serial": "Unknown", "mainboard_version": "Unknown", "mainboard_firmware_vendor": "Unknown", "mainboard_firmware_date": "Unknown", "mainboard_firmware_version": "Unknown", "chassis_vendor": "Unknown", "chassis_type": "Unknown", "chassis_serial": "Unknown", "chassis_version": "Unknown" }, "address_ttl": null, "memory_test_status": -1, "other_test_status_name": "Unknown", "osystem": "", "status_message": "Commissioning", "netboot": true, "physicalblockdevice_set": [], "node_type": 0, "cpu_test_status": -1, "memory_test_status_name": "Unknown", "bcaches": [], "storage_test_status": 0, "system_id": "bhxws3", "status": 1, "commissioning_status": 0, "power_type": "virsh", "locked": false, "numanode_set": [ { "index": 0, "memory": 0, "cores": [] } ], "bios_boot_method": null, "fqdn": "ace-swan.maas", "node_type_name": "Machine", "hostname": "ace-swan", "volume_groups": [], "testing_status": 0, "network_test_status": -1, "other_test_status": -1, "interface_test_status": -1, "hwe_kernel": null, "blockdevice_set": [], "testing_status_name": "Pending", "power_state": "unknown", "min_hwe_kernel": "", "owner": "admin", "distro_series": "", "storage_test_status_name": "Pending", "cpu_speed": 0, "swap_size": null, "cpu_test_status_name": "Unknown", "hardware_uuid": null, "architecture": "amd64/generic", "pool": { "name": "default", "description": "Default pool", "id": 0, "resource_uri": "/MAAS/api/2.0/resourcepool/0/" }, "cache_sets": [], "pod": null, "iscsiblockdevice_set": [], "disable_ipv4": false, "status_action": "", "boot_interface": { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": "", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" }, "cpu_count": 0, "domain": { "authoritative": true, "ttl": null, "resource_record_count": 0, "name": "maas", "is_default": true, "id": 0, "resource_uri": "/MAAS/api/2.0/domains/0/" }, "current_testing_result_id": 7, "default_gateways": { "ipv4": { "gateway_ip": null, "link_id": null }, "ipv6": { "gateway_ip": null, "link_id": null } }, "interface_set": [ { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": "", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" } ], "status_name": "Commissioning", "commissioning_status_name": "Pending", "owner_data": {}, "ip_addresses": [], "raids": [], "network_test_status_name": "Unknown", "description": "", "current_commissioning_result_id": 6, "interface_test_status_name": "Unknown", "current_installation_result_id": null, "zone": { "name": "default", "description": "", "id": 1, "resource_uri": "/MAAS/api/2.0/zones/default/" }, "resource_uri": "/MAAS/api/2.0/machines/bhxws3/" } ```
Tell me about BMC
Cisco UCS Manager X X X
Digital Loggers, Inc. - PDU
Facebook's Wedge *
IPMI X X X X
Intel AMT X X X
Manual
OpenStack Nova X
Rack Scale Design X X X
SeaMicro 15000 X X X
Sentry Switch CDU - PDU
VMWare X X X
Virsh (virtual systems) X X X
