Four questions you may have:
- How do I configure a machine’s power type?
- Show me a catalogue of power parameters, by type.
- Can you give me an example of the virsh power type?
- Which BMC drivers are supported?
CLI power_type code |
Description |
amt |
Intel AMT |
apc |
American Power Conversion (APC) PDU |
dli |
Digital Loggers, Inc. PDU |
hmc |
IBM Hardware Management Console (HMC) |
lxd |
LXD VM |
ipmi |
IPMI |
manual |
Manual power configuration |
moonshot |
HP Moonshot - iLO4 (IPMI) |
mscm |
HP Moonshot - iLO Chassis Manager |
msftocs |
Microsoft OCS - Chassis Manager |
nova |
OpenStack Nova |
openbmc |
OpenBMC Power Driver |
recs_box |
Christmann RECS-Box Power Driver |
redfish |
Redfish |
sm15k |
SeaMicro 15000 |
ucsm |
Cisco UCS Manager |
virsh |
libvirt KVM |
vmware |
VMware |
wedge |
Facebook’s Wedge |
Form field |
Description |
Required |
Power password |
Password to access unit |
Optional |
Power address |
IP address of unit |
Required |
Form field |
Description |
Required |
IP for APC PDU |
Required |
APU PDU node outlet number (1-16) |
PDU node outlet number |
Required |
Power ON outlet delay (seconds) |
outlet power ON delay |
Optional, default=5 |
Form field |
Description |
Required |
Outlet ID |
outlet ID |
Required |
Power address |
Required |
Power user |
Username to login |
Optional |
Power password |
Optional |
Form field |
Description |
Required |
IP for HMC |
Required |
HMC username |
Username to login |
Optional |
HMC password |
Optional |
HMC Managed System server name |
HMC managed server name |
Required |
HMC logical partition |
HMC logical partition of unit |
Required |
Form field |
Description |
Required |
LXD address |
Required |
Instance name |
LXD container instance name |
Required |
LXD password |
Optional |
Form field |
Description |
Choices |
Required |
Power driver |
Power driver |
LAN [IPMI 1.5] |
Required |
LAN_2_0 [IPMI 2.0] |
Power boot type |
Boot type |
Automatic |
Required |
Legacy boot |
EFI boot |
Form field |
Description |
Required |
Power address |
Required |
Power user |
Username to login |
Optional |
Power password |
Optional |
Power hardware address |
Hardware address of unit |
Required |
Form field |
Description |
Required |
IP for MSCM CLI API |
Required |
MSCM CLI API user |
Username to login |
Optional |
MSCM CLI API password |
Optional |
Node ID |
cXnY |
Required |
- where |
X = cartridge number |
Y = node number |
Form field |
Description |
Required |
Power address |
Required |
Power port |
Port where unit is attached |
Optional |
Power user |
Username to login |
Optional |
Power password |
Optional |
Blade ID |
Blade ID (usu. 1-24) |
Required |
Form field |
Description |
Required |
Host UUID |
Host UUID |
Required |
Tenant name |
Tenant name |
Required |
Username |
Username to login |
Required |
Password |
Required |
Auth URL |
URL to access unit |
Required |
Form field |
Description |
Required |
OpenBMC address |
Required |
OpenBMC user |
Username to login |
Required |
OpenBMC password |
Required |
Form field |
Description |
Required |
Node ID |
Node ID |
Required |
Power address |
Required |
Power port |
Optional |
Power user |
Username to login |
Optional |
Power password |
Optional |
Form field |
Description |
Required |
Redfish address |
Required |
Redfish user |
Username to login |
Required |
Redfish password |
Required |
Node ID |
Node ID |
Optional |
Form field |
Description |
Choices |
Required |
Power control type |
IPMI |
Required |
REST API v0.9 |
REST API v2.0 |
Form field |
Description |
Required |
Server UUID |
Server UUID |
Required |
URL for XML API |
XML API URL |
Required |
API user |
API user |
Optional |
API password |
API password |
Optional |
Form field |
Description |
Required |
Address |
URL of VM |
Required |
Password |
API password |
Optional |
Virsh VM ID |
libvirt VM UUID |
Required |
Form field |
Description |
Required |
VM Name |
VM name (if UUID unknown) |
Optional |
VM UUID |
VM UUID (if known) |
Optional |
VMware IP |
IP address of VM |
Required |
VMware username |
Username to access VM |
Required |
VMware password |
Password to access VM |
Required |
VMware API port |
VMware API port number |
Optional |
VMware API protocol |
Optional |
Form field |
Description |
Required |
IP address |
Required |
Power user |
Username to access unit |
Optional |
Power password |
Optional |
Consider a machine backed by VM. Below, a ‘Power type’ of Virsh
has been selected, and the ‘Power address’ of qemu+ssh://ubuntu@192.168.1.2/system
has been entered (replace values as appropriate). The value of ‘Power ID’ is the VM domain (guest) name, here node2
The machine’s hostname – according to MAAS – is a randomly chosen string (here dear.ant
). You should change this hostname to something descriptive, that helps you remember why this machine is in your MAAS network.
Tell me about BMC
Power Driver (X=supported) |
PXE Next Boot |
Power Querying |
Chassis/Pod Configuration |
Enhanced UI Error Reporting |
BMC Enlistment |
American Power Conversion (APC) - PDU |
Cisco UCS Manager |
X |
X |
X |
Digital Loggers, Inc. - PDU |
Facebook's Wedge *
X |
X |
X |
X |
X |
X |
X |
X |
IPMI |
X |
X |
X |
X |
Intel AMT |
X |
X |
X |
Manual |
X |
X |
X |
OpenStack Nova |
X |
Rack Scale Design |
X |
X |
X |
SeaMicro 15000 |
X |
X |
X |
Sentry Switch CDU - PDU |
VMWare |
X |
X |
X |
Virsh (virtual systems) |
X |
X |
X |
The ‘Facebook’s Wedge’ OpenBMC power driver is considered experimental at this time.
