Power management (snap/2.9/UI)
2.7 2.8 2.9
To manage a machine, MAAS must be able to power cycle it, usually through the machine’s BMC^ card. Until you configure the power type, a newly-added machine can’t be enlisted and used by MAAS.
Four questions you may have:
  1. How do I configure a machine’s power type?
  2. Show me a catalogue of power parameters, by type.
  3. Can you give me an example of the virsh power type?
  4. Which BMC drivers are supported?
Configure a machine’s power type
CLI power_type code Description
amt Intel AMT
apc American Power Conversion (APC) PDU
dli Digital Loggers, Inc. PDU
hmc IBM Hardware Management Console (HMC)
lxd LXD VM
ipmi IPMI
manual Manual power configuration
moonshot HP Moonshot - iLO4 (IPMI)
mscm HP Moonshot - iLO Chassis Manager
msftocs Microsoft OCS - Chassis Manager
nova OpenStack Nova
openbmc OpenBMC Power Driver
recs_box Christmann RECS-Box Power Driver
redfish Redfish
sm15k SeaMicro 15000
ucsm Cisco UCS Manager
virsh libvirt KVM
vmware VMware
wedge Facebook’s Wedge
Power catalogue
Intel AMT
Form field Description Required
Power password Password to access unit Optional
Power address IP address of unit Required
IP for APC PDU IP address of unit Required
APU PDU node outlet number (1-16) PDU node outlet number Required
Power ON outlet delay (seconds) outlet power ON delay Optional, default=5
Outlet ID outlet ID Required
Power user Username to login Optional
IP for HMC IP address of unit Required
HMC username Username to login Optional
HMC password Password to access unit Optional
HMC Managed System server name HMC managed server name Required
HMC logical partition HMC logical partition of unit Required
LXD VMs
LXD address IP address of unit Required
Instance name LXD container instance name Required
LXD password Password to access unit Optional
IPMI
Form field Description Choices Required
Power driver Power driver LAN [IPMI 1.5] Required
LAN_2_0 [IPMI 2.0]
Power boot type Boot type Automatic Required
Legacy boot
EFI boot
IP address IP address of unit Required
Power MAC MAC address of unit Optional
K_g K_g BMC key Optional (BETA)
Cipher suite Cipher suite ID - 17 (17 - HMAC-SHA256::HMAC_SHA256_128::AES-CBC-128) Optional (BETA)
3 (3 - HMAC-SHA1::HMAC-SHA1-96::AES-CBC-128)
(blank) (freeipmi-tools default)
8 (8 - HMAC-MD5::HMAC-MD5-128::AES-CBC-128)
12 (12 - HMAC-MD5::MD5-128::AES-CBC-128)
Privilege level IPMI privilege level User Optional (BETA)
Operator
Administrator
Power hardware address Hardware address of unit Required
IP for MSCM CLI API IP address of unit Required
MSCM CLI API user Username to login Optional
MSCM CLI API password Password to access unit Optional
Node ID cXnY Required
- where X = cartridge number
Y = node number
Power port Port where unit is attached Optional
Blade ID Blade ID (usu. 1-24) Required
OpenStack Nova
Host UUID Host UUID Required
Tenant name Tenant name Required
Username Username to login Required
Password Password to access unit Required
Auth URL URL to access unit Required
OpenBMC address IP address of unit Required
OpenBMC user Username to login Required
OpenBMC password Password to access unit Required
Node ID Node ID Required
Redfish
Redfish address IP address of unit Required
Redfish user Username to login Required
Redfish password Password to access unit Required
Node ID Node ID Optional
SeaMicro 15000
System ID System ID Required
Power control type Password to access unit IPMI Required
REST API v0.9
REST API v2.0
Cisco UCS Manager
Server UUID Server UUID Required
URL for XML API XML API URL Required
API user API user Optional
API password API password Optional
virsh - libvirt KVM
Address URL of VM Required
Password API password Optional
Virsh VM ID libvirt VM UUID Required
VMware
VM Name VM name (if UUID unknown) Optional
VM UUID VM UUID (if known) Optional
VMware IP IP address of VM Required
VMware username Username to access VM Required
VMware password Password to access VM Required
VMware API port VMware API port number Optional
VMware API protocol VMware API protocol Optional
Facebook’s Wedge
Power user Username to access unit Optional
The machine’s hostname – according to MAAS – is a randomly chosen string (here dear.ant). You should change this hostname to something descriptive, that helps you remember why this machine is in your MAAS network.
Tell me about BMC
Cisco UCS Manager X X X
Digital Loggers, Inc. - PDU
Facebook's Wedge *
IPMI X X X X
Intel AMT X X X
Manual
OpenStack Nova X
Rack Scale Design X X X
SeaMicro 15000 X X X
Sentry Switch CDU - PDU
VMWare X X X
Virsh (virtual systems) X X X
