- PRIMARY_PG_IP: The IP address of the host that contains the primary database.
- SECONDARY_PG_IP: The IP address of the host that contains the secondary database.
- REP_USER: The internal database user that manages replication on the primary.
- REP_USER_PW: The password of the replication user.
- REP_ARCHIVE: The directory where the database will place files to be replicated.
Primary
Create internal database user
sudo mkdir -p $REP_ARCHIVE
Edit /etc/postgresql/9.5/main/pg_hba.conf
to allow the secondary host to contact this primary host.
host replication $REP_USER $SECONDARY_PG_IP/32 md5
Configure for replication
Edit /etc/postgresql/9.5/main/postgresql.conf
to listen on more than just its localhost interface, turn on replication, and point to the archive directory:
listen_addresses = '*'
wal_level = hot_standby
archive_mode = on
max_wal_senders = 3
Restart the database
Check log file /var/log/postgresql/postgresql-9.5-main.log
on this primary host for any errors.
Secondary
- CPU architecture
- OS type and version
- PostgreSQL version
sudo apt install postgresql
Password:
and put this secondary host in hot standby mode:
hot_standby = on
Configure for recovery
Edit /var/lib/postgresql/9.5/main/recovery.conf
. Specify hot standby mode and enter the information necessary for contacting the primary:
standby_mode = on
Start the database
Start the database:
on this secondary host for any errors.
Verification of replication
hostname | status | power_state
pmatulis-imp-maas | 0 | unknown
node3 | 4 | off
node1 | 6 | on
node2 | 4 | off
node4 | 6 | on
(5 rows)
