List Partitions
"bootable": false,
"id": 9,
"resource_uri":
"/MAAS/api/2.0/nodes/4y3h8a/blockdevices/10/partition/9",
"size": 5360320512,
"type": "partition",
"filesystem": {
"mount_options": null,
"label": null,
"fstype": "lvm-pv",
"mount_point": null
Create Partition
"bootable": false,
"filesystem": null,
"used_for": "Unused",
"id": 10,
"size": 5360320512,
Delete Partition
Format Partition
"id": 9,
"size": 5360320512,
"bootable": false,
"filesystem": {
"mount_point": null,
"fstype": "ext4",
"label": ""
Unformat Partition
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
Mount Partition
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"mount_options": "",
"label": "",
"fstype": "ext4",
"mount_point": "/srv"
Unmount Partition
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"id": 3,
"size": 2000003072
Restrictions
- An EFI partition is required to be on the boot disk for UEFI.
- You cannot place partitions on logical volumes.
- You cannot use a logical volume as a Bcache backing device.
