You can use the CLI to manage the networking elements of MAAS, including subnets, fabrics, VLANs, and spaces. This page shows how to access and edit these elements. See Concepts and terms for the definitions of networking objects, along with a basic networking tutorial (if needed).
Nine questions you may have:
- How do I list available subnets?
- How do I manage subnets?
- How do I manage static routes?
- How do I manage reserved ranges?
- How do I set up a bridge?
- How do I set up a bridge with the MAAS CLI/API?
- How do I set up a bridge with netplan?
List available subnets
To view the list of available subnets, enter the following command:
maas admin subnets read | \
jq -r '(["FABRIC", "VLAN", "DHCP", "SUBNET"]
| (., map(length*"-"))),
(.[] | [.vlan.fabric, .vlan.name, .vlan.dhcp_on, .cidr])
| @tsv' \
| column -t
which produces output something like this:
FABRIC VLAN DHCP SUBNET
Patient-Care untagged true 192.168.123.0/24
fabric-0 untagged false 0.0.0.0/0
fabric-0 untagged false 10.0.0.0/24
fabric-1 untagged false 10.70.132.0/24
fabric-1 untagged false fd42:8b52:7114:9ef8::/64
fabric-3 untagged true 192.168.43.0/24
fabric-3 untagged true 2600:100d:b125:d5e9::/64
fabric-3 untagged true 2600:100d:b120:3933::/64
fabric-3 untagged true 2600:100d:b109:dee0::/64
fabric-3 untagged true 2600:100d:b104:94c0::/64
Managing subnets
You can view the details of an individual subnet with the command:
maas $PROFILE subnet read $SUBNET_ID \
| jq -r '(["NAME","CIDR","GATEWAY","DNS","DISCOVERY","FABRIC","VLAN"]
| (., map(length*"-"))), ([.name,.cidr,.gateway_ip // "-", .allow_dns,.active_discovery,.vlan.name,.vlan.fabric]) | @tsv' | column -t
This command retrieves output similar to this:
NAME CIDR GATEWAY DNS DISCOVERY FABRIC VLAN
192.168.123.0/24 192.168.123.0/24 - true false untagged default
If you don’t know the subnet ID, you can look it up like this:
maas $PROFILE subnets read \
| jq -r '(["NAME", "SUBNET_ID"]
| (., map(length*"-"))), (.[] | [.name, .id]) | @tsv' \
| column -t | grep $SUBNET_NAME
For example, if you’re using the “admin” profile, and your subnet name contains “192.168.123,” you could find the subnet ID with this command:
maas admin subnets read \
| column -t | grep 192.168.123
Subnets support the following configurable values:
Name: Subnet names can be any valid text string, although usually, and by default, they are named with the CIDR of the subnet itself.
CIDR: This is the address parameter for the subnet. In keeping with standard CIDR notation, the number of bits of the prefix are indicated after the slash.
Gateway IP: This is the address of the default gateway for your subnet, which is the IP address that transfers packets to other subnets or networks. Typically, this is simply the first IP address in a block of addresses (the
.1
address). -
DNS: This is the address of a DNS (domain name server, or simply “nameserver”) for your subnet. It’s optional, but can be configured if desired.
Description: This field represents freeform text that you can enter to describe your subnet, as needed to keep important notes attached to the definition of the subnet.
Managed allocation refers to the ability of MAAS to completely manage a subnet. See Subnet management.
Active mapping instructs MAAS to scan the subnet every 3 hours to discover hosts that have not been discovered passively.
Proxy access instructs MAAS to allow clients from this subnet to access the MAAS proxy.
Allow DNS resolution allows subnet clients to use MAAS for DNS resolution.
Fabric: This field allows you to set the subnet’s fabric.
VLAN: This field allows you to set the subnet’s VLAN.
Space is presented for clarity, though spaces are managed at the VLAN level.
Static Routes
To create a static route, use the following command:
maas admin static-routes create source=$SOURCE_SUBNET destination=$DEST_SUBNET \
gateway_ip=$GATEWAY_IP
Reserved ranges
Setting up a bridge
At various times in your MAAS network, you may need to set up a bridge to connect between your machines and MAAS. This section explains several ways of accomplishing this.
You can use the MAAS CLI/API to configure a bridge, with the following procedure:
Create the bridge:
, netplan.yaml
network:
bridges:
br0:
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
interfaces:
- enp1s0
macaddress: 52:54:00:39:9d:f9
mtu: 1500
nameservers:
addresses:
- 10.0.0.2
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
enp1s0:
match:
mtu: 1500
set-name: enp1s0
enp2s0:
match:
macaddress: 52:54:00:df:87:ac
mtu: 1500
set-name: enp2s0
enp3s0:
match:
macaddress: 52:54:00:a7:ac:46
mtu: 1500
set-name: enp3s0
version: 2
