About networking (snap/2.9/CLI)
About MAAS networks
There are elements of MAAS networking that are unique to the product. This section will help you learn:
About network discovery
MAAS constantly listens to the network and reports any discovered devices. Devices are identified when the rack controller observes them communicating on an attached IPv4 subnet. Discovered devices that do not correspond to machines and devices already known to MAAS can be listed via the CLI. If a device advertises a hostname using mDNS (such as with avahi or Bonjour), MAAS will also present the discovered hostname when listing devices.
An unknown discovered device can be added to MAAS as a device, or as a network interface belonging to a machine or device. You can specify values such as ‘Type’, ‘Domain’, ‘IP Assignment’ and ‘Parent’ to be changed prior to the device being added. Indicating a Parent device is optional.
About subnet management
Fabrics, VLANs, and spaces do not require much configuration beyond names and descriptions. You can change the MTU for a VLAN, as well as enable DHCP. None of these options requires detailed instruction.
A subnet, on the other hand, provides a number of configuration options relevant to the day-to-day operation of MAAS. By default, MAAS manages subnets in your configuration, but this is easily changed.
When a subnet is managed, MAAS handles all aspects of IP address allocation. This process includes managing DHCP leases and assigned static addresses. Typically MAAS would have one managed subnet, with any additional subnets unmanaged. This arrangement allows for more control over which subnet gets used for DHCP. Additionally, as detailed below, an unmanaged subnet treats reserved IP ranges differently, in a way that some administrators find more intuitive.
About managed subnets
If needed, you can also define a static route between two subnets. A static route is defined on a per-subnet basis to use a particular gateway, using a configured destination.
About unmanaged subnets
About IP address tracking
When you enable IP address tracking, MAAS will keep track of all assigned addresses, regardless of whether they come from managed or unmanaged subnets.
About IPv6
Support for IPv6 in MAAS is similar to support for IPv4. This subsection will help you learn:
A rack controller in an IPv6 context needs to have the region API server URL specified with brackets:
http://[::1]:5240/MAAS/
About enabling IPv6
About IPv6 subnets
If you define a reserved static IP range, then machines deployed on the subnet will get a static address in this range. Since IPv6 networks usually are 64 bits wide, you can be generous with the range size. You can typically leave the netmask and broadcast address fields blank.
About IPV6 routing
If you need RAs, but your gateway does not send them, you could install and configure radvd somewhere on the network to advertise its route.
About availability zones
This subsection explains some characteristics and uses of availability zones. Here you have the opportunity to learn:
About fault tolerance
About service performance
About power management
