Network testing (deb/2.7/CLI)
Four questions you may have:
  1. How do I use network link testing?
  2. How can I detect slow network links?
  3. How do I use network validation and testing scripts?
  4. How can I customise network testing?
| @tsv' | column -t
| @tsv' | column -t
Administrators can change or update the link and interface speeds after manual changes
to the connection:
Network validation and testing scripts
To test individual interfaces, for example, you could issue the following command:
Customise network testing
