How to test networking (snap/3.0/UI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
MAAS can check this link and recognise that there’s no connectivity, which alleviates hard-to-detect network issues:
