How to test networking (snap/3.0/CLI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
| @tsv' | column -t
| @tsv' | column -t
Administrators can change or update the link and interface speeds after manual changes
to the connection:
To test individual interfaces, for example, you could issue the following command:
