About machines (deb/2.9/CLI)
Machines are the heart of MAAS. They are the backbone of your data centre application(s), providing the functions that are relevant to your customers. MAAS manages their transit through a life-cycle, from adding and enlistment, through commissioning, allocation, and deployment, finally being released back to the pool, or retired altogether. You can move them around, create redundant versions (even in other geographies you can access), and basically rearrange them to the extent that your network allows.
In this article, you will learn:
About the machine life-cycle
One of the most important things to understand about machines is their life-cycle. Machines can be discovered or added, commissioned by MAAS, acquired, deployed, released, marked broken, tested, put into rescue mode, and deleted. In addition, pools, zones, and tags can be set for machines.
About enlisting deployed machines
In addition, already-deployed machines can be enlisted by MAAS, via the MAAS 3.1 CLI, and their operating parameters can be gathered with a special MAAS script. Because already-deployed machines were not deployed by MAAS, most of the standard MAAS commands will not affect the machine and may, at times, return some odd results. This is not errant behaviour; the goal of enlisting deployed machines is to avoid disturbing their workload. These unusual behaviours will be documented throughout this article and the following machine articles.
MAAS version 3.0 cannot enlist deployed machines. Please upgrade to MAAS version 3.1 or greater to gain this capability.
MAAS version 2.9 cannot enlist deployed machines. Please upgrade to MAAS version 3.1 or greater to gain this capability.
All of these states and actions represent the possible life-cycle of a machine. This life-cycle isn’t strict or linear – it depends on how you use a machine – but it’s useful to give a general overview of how machines tend to change states. In the discussion that follows, states and actions are shown in bold type.
  1. Machines start as servers in your environment, attached to a network or subnet MAAS can manage.
  2. If machines are configured to netboot, MAAS can discover them and present them to you for possible commissioning, changing their state to New.
  3. When you select a machine that is marked New, you can choose to commission it. If you add a machine manually, it is automatically commissioned.
  4. Machines that have successfully commissioned can be acquired and deployed. Machines that don’t successfully commission can be marked broken (and later recovered when the issues are resolved).
  5. Resolving problems with machines usually involve testing the machine.
  6. Once you’ve deployed a machine, and you’re done with it, you can release it.
  7. You can place a machine in rescue mode, which allows you to SSH to a machine to make configuration changes or do other maintenance. Once you’re done, you can exit rescue mode*.
  8. Any time a machine is on, you have the option to select it and power off that machine.
  9. You can abort any operation that’s in progress.
  10. You also have the option to set tags, availability zone, or resource pool at various stages along the way.
Since these actions are not necessarily sequential, and the available actions change as the machine state changes, it’s not very useful to make a state diagram or flowchart. Instead, consider the following table:
Action/State New Ready Acquired Deployed Locked Rescue Broken Enlist deployed
Commission X X X X (w/scripts)
Acquire X
Deploy X X
Release X X X (no return)
Power on X X
Power off
Test X X X X X
Rescue mode X X X X X
Exit rescue X
Mark broken X X X (no return)
Mark fixed X
Lock X X
Unlock X X
Tag X X X X X X X
Set zone X X X X X X X
Set…pool X X X X X X X
Delete X X X X X X X*
*Machine is removed from the view of MAAS, but remains deployed with original workload.
Commission X X X
Acquire X
Deploy X X
Release X X
Power on X X
Power off
Test X X X X X
Exit rescue X
Mark broken X X
Mark fixed X
Lock X
Unlock X
Tag X X X X X X
Delete X X X X X X
When a machine is in the state listed in a column, it is possible to take the row actions marked with an “X.”
You access these actions from the “Take action” menu in the upper right corner of the machine listing. Note that some actions, such as “Mark broken” or “Lock,” may be hidden when they are not available.
In the case of already-deployed machines enlisted by MAAS, some of the possible actions may appear to be available, but either don’t work or ultimately appear to fail, without affecting the actual status of the deployed machine.
You can change machine state, via the CLI, with the machine command, which offers the following options:
$ maas admin machine -h
usage: maas admin machine [-h] COMMAND ...
Manage an individual machine.
optional arguments:
drill down:
  COMMAND
    details             Get system details
    power-parameters    Get power parameters
    set-workload-annotations
			Set key=value data
    set-owner-data      Deprecated, use set-workload-annotations.
    query-power-state   Get the power state of a node
    power-on            Turn on a node
    power-off           Power off a node
    test                Begin testing process for a node
    override-failed-testing
			Ignore failed tests
    abort               Abort a node operation
    deploy              Deploy a machine
    release             Release a machine
    commission          Commission a machine
    set-storage-layout  Change storage layout
    mount-special       Mount a special-purpose filesystem
    unmount-special     Unmount a special-purpose filesystem
    clear-default-gateways
			Clear set default gateways
    get-curtin-config   Get curtin configuration
    restore-networking-configuration
			Restore networking options
    restore-storage-configuration
			Restore storage configuration
    restore-default-configuration
			Restore default configuration
    mark-broken         Mark a machine as Broken
    mark-fixed          Mark a machine as Fixed
    rescue-mode         Enter rescue mode
    exit-rescue-mode    Exit rescue mode
    lock                Lock a machine
    unlock              Unlock a machine
    read                Read a node
    update              Update a machine
    delete              Delete a machine
A machine is identified by its system_id.
In the case of already-deployed machines enlisted by MAAS, some of the possible actions may fail with unusual results, such as this exchange when attempting to turn off an already-deployed machine enlisted by MAAS:
$ maas admin machine power-off t8b7cw
null
Note that the immediate return is Success, but the machine-readable output is null. After executing this command on an already-deployed machine, you should find that the deployed machine was not affected by the power-off command, since the power-type was set to manual. This is an expected behaviour.
optional arguments:
drill down:
  COMMAND
			Set key=value data
			Ignore failed tests
    lock                Lock a machine
    read                Read a node
[/tabs]
For a better understanding of these states and actions, see Node statuses and Machine actions.
About enlistment
When you configure a machine to netboot – and turn it on while connected to the network – MAAS will enlist it, giving it a status of “New.” You can also add a machine manually. In either case, the next step is commissioning, which boots the machine into an ephemeral Ubuntu kernel so that resource information can be gathered. You can also run custom commissioning scripts to meet your specific needs.
About the enlistment process
Typically, the next step will be to commission the machine. As an alternative to enlistment, an administrator can add a machine manually. Typically this is done when enlistment doesn’t work for some reason. Note that when you manually add a machine, MAAS automatically commissions the machine as soon as you’ve added it.
After the commissioning process, MAAS places the machine in the ‘Ready’ state. ‘Ready’ is a holding state for machines that are commissioned, waiting to be deployed when needed.
About cloning machines
MAAS 3.1 provides the ability to quickly clone or copy configuration from one machine to one or more machines, via the MAAS UI, providing convenient access to an existing API feature… This is a step towards machine profile templating work.
Creating a machine profile is a repetitive task. Based on the responses to our survey – and multiple forum posts, we have learned that most users create multiple machines of the same configuration in batches. Some users create a machine profile template and loop them through the API, while some create a script to interface with the CLI. However, there is no easy way to do this in the UI except by going through each machine and configuring them individually.
MAAS API already has the cloning functionality, but it was never exposed in the UI. Hence, users may not know that this API feature exists, nor is there any current documentation about how to use this feature. Although the current cloning API feature does not solve all machine profile templating problems, it is a great place for us to start moving in the direction of machine templates.
About copying machine configurations
As a MAAS user – API or UI – you may want to copy the configuration of a given machine and apply it to multiple existing machines. Assuming that at least one machine is already set to the desired configuration, you should be able to apply these same settings to a list of destination machines. This means that a user should be able to:
  • select the source machine to copy from.
  • validate that the source machine exists.
  • select at least 1 destination machine.
  • validate that the destination machine(s) exist.
  • edit the source machine or destination machines, if needed.
  • know at all times which machines are affected.
  • see the cloned machines when cloning is successful, or
  • get clear failure information, if cloning fails.
About choosing configuration items to copy
As a MAAS user, you will likely want to select whether storage, network, or both configurations should be cloned. The cloning API allows users to choose interfaces and storage separately. Thus, this new feature should allow the user to:
  • clone only the interface (network) configuration.
  • clone only the storage configuration.
  • clone both configurations.
About cloning restrictions
In order for cloning to succeed, a few restrictions must be met:
  1. The destination interface names must be the same source.
  2. The destination drive must be equal to or larger than the source drive.
  3. For static IPs, a new IP will be allocated to the interface on the destination machine
In general, when adding a machine to MAAS, it network boots the machine into an ephemeral environment to collect hardware information about the machine. While this is not a destructive action, it doesn’t work if you have machines that are already running a workload.
For one, you might not be able to disrupt the workload in order to network boot it. But also, the machine would be marked as Ready, which is incorrect.
When adding a machine, you may specify that the machine is already deployed. In that case, it won’t be going through the normal commissioning process and will be marked as being deployed.
Such machines lack hardware information. In order to update the information, a script is provided to run a subset of the commissioning scripts and send them back to MAAS.
Some of the normal commands that work on deployed machines will not work on an already-deployed machine enlisted by MAAS.
Cloning machines is only available in MAAS versions 3.1 and greater.
About BMC enlistment
For IPMI machines, you only need to provide IPMI credentials. MAAS automatically discovers the machine and runs enlistment configuration by matching the BMC address. For non-IPMI machines, you must specify a non-PXE MAC address. MAAS automatically discovers the machine and runs enlistment configuration by matching the non-PXE MAC address.
About commissioning machines
  1. DHCP server is contacted
  3. machine boots
  5. cloud-init runs built-in and custom commissioning scripts
  6. machine shuts down
Commissioning requires 60 seconds.
About commissioning NUMA and SR-IOV nodes
When using these nodes, you can specify a node index for interfaces and physical block devices. MAAS will display the NUMA node index and details, depending upon your configuration, to include the count of NUMA nodes, number of CPU cores, memory, NICs, and node spaces for bonds and block devices. You can also filter machines by CPU cores, memory, subnet, VLAN, fabric, space, storage, and RAID, among others.
About MAAS commissioning scripts
Scripts can be selected to run from web UI during commissioning, by testing hardware, or from the command line. Note that MAAS only runs built-in commissioning scripts during enlistment. Custom scripts can be run when you explicitly choose to commission a machine. A typical administrator workflow (with machine states), using customised commissioning scripts, can be represented as:
  • maas-support-info: MAAS gathers information that helps to identify and characterise the machine for debugging purposes, such as the kernel, versioning of various components, etc. Runs in parallel with other scripts.
  • maas-lshw: this script pulls system BIOS and vendor info, and generates user-defined tags for later use. Runs in parallel with other scripts.
  • 20-maas-01-install-lldpd: this script installs the link layer discovery protocol (LLDP) daemon, which will later capture networking information about the machine. This script provides some extensive logging.
  • maas-list-modaliases: this script figures out what hardware modules are loaded, providing a way to autorun certain scripts based on which modules are loaded. Runs in parallel with other scripts.
  • 20-maas-02-dhcp-unconfigured-ifaces: MAAS will want to know all the ways the machine is connected to the network. Only PXE comes online during boot; this script brings all the other networks online so they can be recognised. This script provides extensive logging.
  • maas-get-fruid-api-data: this script gathers information for the Facebook wedge power type. Runs in parallel with other scripts.
  • maas-serial-ports: this script lists what serial ports are available on the machine. Runs in parallel with other scripts.
As of MAAS version 3.0, 40-maas-01-network-interfaces is no longer used by MAAS.
  • 40-maas-01-network-interfaces: this script is just used to get the IP address, which can then be associated with a VLAN/subnet.
  • 50-maas-01-commissioning: this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, details about attached USB and PCI devices, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
  • 50-maas-01-commissioning: this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
  • maas-capture-lldp: this script gathers LLDP network information to be presented on the logs page; this data is not used by MAAS at all. Runs in parallel with other scripts.
  • maas-kernel-cmdline: this script is used to update the boot devices; it double-checks that the right boot interface is selected.
Commissioning runs the same dozen or so scripts as enlistment, gathering all the same information, but with these seven caveats:
  1. Commissioning also runs user-supplied commissioning scripts, if present. Be aware that these scripts run as root, so they can execute any system command.
  2. Commissioning runs test scripts which are not run during enlistment.
  3. Commissioning scripts can send BMC configuration data, and can be used to configure BMC data.
  4. The environment variable BMC_CONFIG_PATH is passed to serially run commissioning scripts; these scripts may write BMC power credentials to BMC_CONFIG_PATH in YAML format, where each key is a power parameter. The first script to write BMC_CONFIG_PATH is the only script allowed to configure the BMC, allowing you to override MAAS’ built-in BMC detection. If the script returns 0, that value will be send to MAAS.
  5. All built-in commissioning scripts have been migrated into the database.
  6. maas-run-remote-scripts is capable of enlisting machines, so enlistment user-data scripts have been removed.
  7. The metadata endpoints http://<MAAS>:5240/<latest or 2012-03-01>/ and http://<MAAS>:5240/<latest or 2012-03-01>/meta-data/ are now available anonymously for use during enlistment.
  1. enable_ssh: Optional integer. Controls whether to enable SSH for the commissioning environment using the user’s SSH key(s). ‘1’ == True, ‘0’ == False. Roughly equivalent to the Allow SSH access and prevent machine powering off in the web UI.
  2. skip_bmc_config: Optional integer. Controls whether to skip re-configuration of the BMC for IPMI based machines. ‘1’ == True, ‘0’ == False.
  3. skip_networking: Optional integer. Controls whether to skip re-configuring the networking on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain network configuration in the web UI.
  4. skip_storage: Optional integer. Controls whether to skip re-configuring the storage on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain storage configuration in the web UI.
  5. commissioning_scripts: Optional string. A comma separated list of commissioning script names and tags to be run. By default all custom commissioning scripts are run. Built-in commissioning scripts always run. Selecting update_firmware or configure_hba will run firmware updates or configure HBA’s on matching machines.
  6. testing_scripts: Optional string. A comma separated list of testing script names and tags to be run. By default all tests tagged commissioning will be run. Set to none to disable running tests.
  7. parameters: Optional string. Scripts selected to run may define their own parameters. These parameters may be passed using the parameter name. Optionally a parameter may have the script name prepended to have that parameter only apply to that specific script.
About machine commissioning logs
MAAS keeps extensive logs of the commissioning process for each machine. These logs present an extremely detailed, timestamped record of completion and status items from the commissioning process.
About disabling individual boot methods
It is possible to disable individual boot methods. This must be done via the CLI. When a boot method is disabled MAAS will configure MAAS controlled isc-dhcpd to not respond to the associated boot architecture code. External DHCP servers must be configured manually.
To allow different boot methods to be in different states on separate physical networks using the same VLAN ID configuration is done on the subnet in the UI or API. When using the API boot methods to be disabled may be specified using the MAAS internal name or boot architecture code in octet or hex form.
For MAAS 3.0 and above, the following boot method changes have been implemented:
  • UEFI AMD64 HTTP(00:10) has been re-enabled.
  • UEFI ARM64 HTTP(00:13) has been enabled.
  • UEFI ARM64 TFTP(00:0B) and UEFI ARM64 HTTP(00:13) will now provide a shim and GRUB signed with the Microsoft boot loader keys.
  • grub.cfg for all UEFI platforms has been updated to replace the deprecated linuxefi and initrdefi commands with the standard linux and initrd commands.
  • GRUB debug may now be enabled by enabling rackd debug logging.
Disabling boot methods is available in MAAS version 3.0 or greater.
About automatic script selection by hardware type
When selecting multiple machines, scripts which declare the for_hardware field will only run on machines with matching hardware. To automatically run a script when ‘Update firmware’ or ‘Configure HBA’ is selected, you must tag the script with ‘update_firmware’ or ‘configure_hba’.
About script results
The YAML file must represent a dictionary with these two fields:
  1. result: The completion status of the script. This status can be passed, failed, degraded, or skipped. If no status is defined, an exit code of 0 indicates a pass while a non-zero value indicates a failure.
2.results: A dictionary of results. The key may map to a results key defined as embedded YAML within the script. The value of each result must be a string or a list of strings.
Optionally, a script may define what results to return in the YAML file in the metadata fields… The results field should contain a dictionary of dictionaries. The key for each dictionary is a name which is returned by the results YAML. Each dictionary may contain the following two fields:
  1. title - The title for the result, used in the UI.
  2. description - The description of the field used as a tool-tip in the UI.
Here is an example of “degrade detection”:
#!/usr/bin/env python3
# name: example
# results:
#   memspeed:
#     title: Memory Speed
#     description: Bandwidth speed of memory while performing random read writes
import os
import yaml
memspeed = some_test()
results = {
    'results': {
        'memspeed': memspeed,
if memspeed < 100:
if result_path is not None:
About tags and scripts
About debugging script failures
You can individually access the output from both completed and failed scripts.
About testing hardware
About machine hardware & test logs
MAAS logs test results and allows you to view a summary of tests run against a particular machine. You can also example details on any particular tests:
You can also examine the “raw” log output:
About testing machine networking
About post-commission configuration
Once commissioned, you can configure the machine’s network interface(s). Specifically, when a machine’s status is either “Ready” or “Broken”, interfaces can be added/removed, attached to a fabric and linked to a subnet, and provided an IP assignment mode. Tags can also be assigned to specific network interfaces.
About acquisition and deployment
Once a machine has been commissioned, the next logical step is to deploy it. Deploying a machine means, effectively, to install an operating system on it, along with any other application loads you wish to run on that machine.
Before deploying a machine, MAAS must acquire it (status ‘Allocated’). Acquiring (“allocating”) a machine reserves the machine for the exclusive use of the acquiring process. The machine is no longer available to any other process, including another MAAS instance, or a process such as Juju.
MAAS also supports machine customisation with a process called “preseeding.” For more information about customising machines, see How to customise machines.
  3. machine boots
  5. cloud-init triggers deployment process
  6. curtin installation script runs
  7. Squashfs image (same as above) is placed on disk
The curtin installer uses an image-based method and is now the only installer used by MAAS. Although the older debian-installer method has been removed, curtin continues to support preseed files. For more information about customising machines see How to customise machines.
Before deploying, you should take two key actions:
  1. Review and possibly set the Ubuntu kernels and the Kernel boot options that will get used by deployed machines.
  2. Ensure any pertinent SSH keys are imported (see SSH keys) to MAAS so it can connect to deployed machines.
About machine event logs
Event logs display a list of timestamped status updates for events and actions performed on the machine:
Detailed discussion of this event log can be found under the Logging section of this documentation.
About adding machines
  2. If you add a machine manually, MAAS will automatically commission it. There are also ways to turn off this automatic commissioning, should you desire to do so.
Configuring a computer to boot over PXE is done via its BIOS, often referred to as “netboot” or “network boot”. Normally, when you add a machine manually, MAAS will immediately attempt to commission the machine. Note that you will need to configure the underlying machine to netboot, or commissioning will fail. MAAS cannot handle this configuration for you. While the correct method for configuring network boot depends heavily on your server, there are two common elements:
  1. The network card on your server must be able to support PXE, i.e., your NIC – whether independent or integrated on a motherboard – must have a boot PROM that supports network booting. You’ll need to consult the documentation for the machine in question to determine this. Note that in MAAS versions before 2.5, you are required to provide the MAC address of the PXE interface when adding a new machine manually.
Regardless of how MAAS adds a machine, there are no special requirements for the underlying machine itself, other than being able to netboot. In particular, there is no need to install an operating system on it.
About the machine list
In the illustration below, you see the machine list for a typical small hospital data centre, including servers ready and allocated for functions like Pharmacy, Orders, Charts, and so on:
Rolling the cursor over status icons often reveals more details. For example, a failed hardware test script will place a warning icon alongside the hardware type tested by the script. Rolling the cursor over this will reveal which test failed. Likewise, you can find some immediate options by rolling over the column data items in the machines table.
The ‘Add hardware’ drop-down menu is used to add either new machines or a new chassis. This menu changes context when one or more machines are selected from the table, using either the individual checkboxes in the first column or the column title checkbox to select all.
With one or more machines selected, the ‘Add hardware’ drop-down menu moves to the left, and is joined by the ‘Take action’ menu. This menu provides access to the various machine actions that can be applied to the selected machine(s):
The ‘Filter by’ section limits the machines listed in the table to selected keywords and machine attributes.
FQDN               POWER  STATUS     OWNER  TAGS     POOL       NOTE     ZONE
52-54-00-15-36-f2  off    Ready      -      Orders   Prescrbr   @md-all  Medications
52-54-00-17-64-c8  off    Ready      -      HRMgmt   StaffComp  @tmclck  Payroll
52-54-00-1d-47-95  off    Ready      -      MedSupp  SuppServ   @storag  Inventory
52-54-00-1e-06-41  off    Ready      -      PatPrtl  BusOfc     @bzstns  BizOffice
52-54-00-1e-a5-7e  off    Ready      -      Pharm    Prescrbr   @rxonly  Pharmacy
52-54-00-2e-b7-1e  off    Allocated  admin  NursOrd  NurServ    @nstns   Nursing
52-54-00-2e-c4-40  off    Allocated  admin  MedAdmn  NurServ    @rxonly  Nursing
52-54-00-2e-ee-17  off    Deployed   admin  Charts   ProServ    @md-all  Physician
These example machines would typically be duplicated in several different geographies, with a quick way to switch to a redundant node, should anything go wrong (e.g., high availability). We used the word node there because, In the network language of MAAS, machines are one of several different types of nodes. A node is simply a network-connected object or, more specifically, an object that can independently communicate on a network. MAAS nodes include controllers, network devices, and of course, machines.
Looking back at the example above, you can see that there are several columns in the machine list, depending on your view:
  1. FQDN | MAC: The fully qualified domain name or the MAC address of the machine.
  2. Power: ‘On’, ‘Off’ or ‘Error’ to highlight an error state.
  3. Status: The current status of the machine, such as ‘Ready’, ‘Commissioning’ or ‘Failed testing’.
  4. Owner: The MAAS account responsible for the machine.
  5. Cores: The number of CPU cores detected on the machine.
  6. RAM: The amount of RAM, in GiB, discovered on the machine.
  7. Disks: The number of drives detected on the machine.
  8. Storage: The amount of storage, in GB, identified on the machine.
About the machine summary
Click a machine’s FQDN or MAC address to open a detailed view of a machine’s status and configuration.
The default view is ‘Machine summary’, presented as a series of cards detailing the CPU, memory, storage and tag characteristics of the machine, as well as an overview of its current status. When relevant, ‘Edit’ links take you directly to the settings pane for the configuration referenced within the card. The machine menu bar within the web UI also includes links to logs, events, and configuration options:
The machine status card presents an overview of CPU, memory, storage, tags, and general settings:
The first card presents some basics of the machine resources and configuration:
Here are some details on what this card presents, with details on in-card links described in following sections:
  • OVERVIEW the machine status (in this case “Deployed”), and lists OS version information.
  • CPU shows the specifics of the CPU(s), including a link to test the processor(s).
  • MEMORY gives the total available RAM for this machine, along with a test link.
  • STORAGE presents the total amount of storage available and the number of disks that provide that storage. There are two links here: one gives the storage layout (with the opportunity to change it for devices that are in ‘Ready’ or ‘Allocated’ states.
  • Owner identifies the owner of the machine.
  • Domain indicates the domain in which the machine exists.
  • Zone shows the AZ in which this machine resides, along with a link to edit the machine configuration (to change the AZ, if desired).
  • Resource pool shows the pool to which this machine has been assigned, and an edit link.
  • Power type gives the current power type, which links to the relevant edit form.
  • Tags presents the list of tags associated with this machine, editable via the link.
Note that clicking any of the links in this card will either present a pop-up form or take you to another item in the machine menu – so using the browser “back” button will take you completely away from this machine’s page. For example, you can choose the “Test CPU” option, which brings up this overlay:
From this screen, you can choose test scripts and run the tests (in the background) as the interface returns to the Machine summary. A linked note in the CPU block lets you know that the tests are in progress:
And you can watch the results under the “Tests” option in the Machine menu:
The rest of the cards on the Machine summary are either self-explanatory, or they’re covered in the sections below. The main point is this: You can see that nearly everything about machines takes place within the main menu’s “Machines” option.
Handling attached USB and PCI devices
The machines in your MAAS may have devices attached to them via USB or PCI interface, such as keyboards, cameras, network cards, GPUs, etc. MAAS will recognise these devices and make them visible to you when a machine is commissioned.
For example, the machine details presents USB and PCI devices like this:
Note that this page now includes two new tabs: “PCI devices” and “USB.” For each USB/PCI device attached to your machine, these tabs will list:
  • device type
  • vendor ID
  • a product description
  • a product ID
  • the driver name
  • the containing NUMA node (if any)
  • the device address
A typical PCI device tab would look something like this:
The USB tab presents similar information in the same format.
If you are upgrading from a previous version of MAAS, PCI and USB devices aren’t modelled, so you will have to recommission the machine to capture these devices.
Once you’ve commissioned the machine, you have the option of deleting
PCI/USB devices from the machine in any machine state, via the CLI
only, using the following command:
maas $PROFILE node-device delete $SYSTEM_ID $DEVICE_ID
where:
  • $PROFILE = your user profile (e.g., “admin”)
  • $SYSTEM_ID = the ID of the machine in question (e.g., “ngx7ry”)
  • $DEVICE_ID = the ID of the device you want to delete
If the device is still present in the system, it will be recognised again (and thus “recreated”)
when the machine is commissioned again.
About machine network info
The Network “tab” provides you with a way to view/edit the network and interface configuration for a machine:
In the case of this deployed machine, there are not many editing options. If the machine is in a ‘Ready’ state, though, altering the network configuration is possible, as shown in the screenshot above.
About machine configuration info
There are two sections to this tab. The “Machine configuration” section, shown above, offers some general parameters, mostly related to how this machine is grouped and categorised. More information on these options are found in the relevant sections of the documentation (e.g., tags, resource pools, and so forth).
The “Power configuration” supplies the parameters necessary for MAAS to access the machine to PXE-boot it:
USB and PCI devices are supported in MAAS version 3.0 and greater.
About resource pools
About tags
  • VM hosts
  • network interfaces
  • devices
  • nodes (in the CLI only)
About annotations
About storage
About machine storage info
The Storage tab on the machine list brings up a form that allows you to view/edit the file system, partitioning and storage parameters for the selected machine:
This tab describes the filesystem(s) in use, as well as the available and used partitions for this machine.
About block devices
Physical
Virtual
About partitions
About storage restrictions
About VMFS datastores
About UEFI booting
About disk erasure
About disk erasure types
  1. Standard erasure
  2. Secure erasure
  3. Quick erasure
About standard erasure
About secure erasure
About quick erasure
