About machine customisation
This page explains machine customisations with MAAS. Prior to deployment, MAAS machines can be customised in a number of ways, including:
  • machine storage.
  • commissioning and deployment configurations (known as “pre-seeding”).
  • custom Ubuntu kernels.
  • kernel boot options.
  • resource pools.
In MAAS v3.2 and higher, machines can also be customised post-deployment, while running, either by changing out the physical hardware, or by altering the VM from the VM host side. This will allow you to:
  • add or remove disks
  • add or remove network interfaces
  • add or remove PCI devices
  • add or remove USB devices
You cannot update these parameters from within MAAS on a deployed machine.
While deploying a machine, you can configure that machine to periodically sync its hardware configuration. Deployed machines will passively update changes to the BMC and tags for that machine, on-the-fly, as these changes are made.
This section will explain these possible customisations, and provide detailed instructions on how to customise your own machines as desired.
Customising storage
MAAS doesn’t currently support deploying with ZFS for devices other than the root one. For this reason, ZFS is not recommended.
MAAS supports storage configuration for CentOS and RHEL deployments. Support includes RAID, LVM, and custom partitioning with different file systems (ZFS and bcache excluded). This support requires a newer version of Curtin, available as a PPA^.
UEFI booting
UEFI must be enabled or disabled for the lifespan of the machine. For example, do not enlist a machine with UEFI enabled, and then disable it before commissioning. It won’t work!
Block devices
*Physical
*Virtual
Partitions
Storage restrictions
VMFS data stores
Final storage mods
Disk erasure
Disk erasure pertains to the erasing of data on each of a machine’s disks when the machine has been released (see Release action back into the pool of available machines. The user can choose from among three erasure types before confirming the Release action. A default erasure configuration can also be set.
Erasure types
  1. Standard erasure - Overwrites all data with zeros.
  2. Secure erasure - Although effectively equivalent to Standard erase, Secure erase is much faster because the disk’s firmware performs the operation. Because of this, however, some disks may not be able to perform this erasure type (SCSI, SAS, and FC disks in particular).
  3. Quick erasure - Same as Standard erase but only targets the first 1 MB and the last 1 MB of each disk. This removes the partition tables and/or superblock from the disk, making data recovery difficult but not impossible.
If all three options are checked when the machine is released, the following order of preference is applied:
  2. If it does not, then use ‘quick erase’
It is very important to pay close attention to your selections when erasing disks.
Pre-seeding
During machine enlistment, deployment, commissioning and machine installation, MAAS sends Tempita-derived^ configuration files to the cloud-init^ process running on the target machine. MAAS refers to this process as preseeding. These preseed files are used to configure a machine’s ephemeral and installation environments and can be modified or augmented to a custom machine configuration.
Preseeding in MAAS can be achieved in two ways:
  1. Curtin^, a preseeding system similar to Kickstart or d-i (Debian Installer), applies customisation during operating system (OS) image installation. MAAS performs these changes on deployment, during OS installation, but before the machine reboots into the installed OS. Curtin customisations are perfect for administrators who want their deployments to have identical setups all the time, every time. This blog post^ contains an excellent high-level overview of custom MAAS installs using Curtin.
  2. Cloud-init^, a system for setting up machines immediately after instantiation. cloud-init applies customisations after the first boot, when MAAS changes a machine’s status to ‘Deployed.’ Customisations are per-instance, meaning that user-supplied scripts must be re-specified on redeployment. Cloud-init customisations are the best way for MAAS users to customise their deployments, similar to how the various cloud services prepare VMs when launching instances.
Templates (snap)
The Tempita^ template files are found in the /var/snap/maas/current/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
Templates (deb)
The Tempita^ template files are found in the /etc/maas/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
Phase Filename prefix
Enlistment enlist
Commissioning commissioning
Installation curtin (Curtin)^
The enlist template, for example, contains only minimal variables, whereas enlist_userdata includes both user variables and initialisation logic.
Tempita’s inheritance mechanism is the reverse of what you might expect. Inherited files, such as enlist_userdata, become the new template which can then reference variables from the higher-level file, such as enlist.
Template naming
Some earlier versions of MAAS only support Ubuntu. If the machine operating system is Ubuntu, then filenames without {os} will also be tried, to maintain backward compatibility.
  1. {prefix}_{os}_{node_arch}_{node_subarch}_{release}_{node_name} or {prefix}_{node_arch}_{node_subarch}_{release}_{node_name}
  2. {prefix}_{os}_{node_arch}_{node_subarch}_{release} or {prefix}_{node_arch}_{node_subarch}_{release}
  3. {prefix}_{os}_{node_arch}_{node_subarch} or {prefix}_{node_arch}_{node_subarch}
  4. {prefix}_{os}_{node_arch} or {prefix}_{node_arch}
  5. {prefix}_{os}
  6. {prefix}
  7. generic
The prefix can be either enlist, enlist_userdata, commissioning, curtin, curtin_userdata or preseed_master. Alternatively, you can omit the prefix and the following underscore.
For example, to create a generic configuration template for Ubuntu 16.04 Xenial running on an x64 architecture, the file would need to be called ubuntu_amd64_generic_xenial_node.
To create the equivalent template for curtin_userdata, the file would be called curtin_userdata_ubuntu_amd64_generic_xenial_node.
Ubuntu kernels
  • General availability kernels
  • Hardware enablement kernels
  • Hardware enablement kernels (pre-release)
  • Low latency kernels
GA kernels
HWE kernels
See LTS Enablement Stack^ (Ubuntu wiki) for the latest information on HWE.
Pre-release HWE
See Rolling LTS Enablement Stack (Ubuntu wiki)^ for more information.
Low-latency kernels
The low-latency kernel is based on the GA kernel, but uses a more aggressive configuration to reduce latency. It is categorised as a soft real-time kernel. For more information, see Criteria for real-time computing^ (Wikipedia).
Choosing a kernel
Kernel boot options
MAAS can specify kernel boot options to machines on both a global basis (UI and CLI) and a per-machine basis (CLI-only). A full catalogue of available options can be found in the Linux kernel parameters list^ at kernel.org^.
Resource pools
Administrators can manage resource pools on the Machines page in the web UI, under the Resource pools tab, or with the MAAS CLI. Also note that all MAAS installations have a resource pool named “default.” MAAS automatically adds new machines to the default resource pool.
