Tags and annotations (snap/2.7/CLI)
  • VM hosts
  • network interfaces
  • devices
  • nodes (in the CLI only)
Work with tags
This section is devoted to procedures for working with tags. We begin with some general operations that apply to all tags types, such as naming conventions and basic mechanics. We then walk through the various tag types, providing procedures that will help you create, assign, remove, delete, list, view, and filter tags, covering the nuances of each type.
Work with tags, independent of application
This subsection will explain how to:
Create a tag
    "name": "new_tag",
    "definition": "",
    "kernel_opts": "",
Create tags with built-in kernel options
For example:
    "name": "nomodeset_tag",
    "definition": "",
| @tsv' | column -t
virtual
Delete a tag
maas admin tag delete zorko
Update a tag
For example:
    "name": "new_tag",
    "definition": "",
    "kernel_opts": "",
List all tags available on this MAAS
For example:
virtual
Rebuild a tag
    "rebuilding": "virtual"
Work with machine tags
Assign machine tags to a machine
For example:
   "added": 1,
   "removed": 0
| @tsv' | column -t
hostname       sysid   machine_tags
divine-stork   8b3ypp  pod-console-logging  virtual
casual-prawn   4end6r  pod-console-logging  virtual
driven-teal    tgaat6  pod-console-logging  virtual
immune-beetle  43xand  pod-console-logging  virtual
good-osprey    napfxk  pod-console-logging  virtual
smart-hen      c4rwq7  pod-console-logging  virtual
boss-satyr     xn8taa  pod-console-logging  androko
golden-martin  8fxery  pod-console-logging  virtual
crack-guinea   qk4b3g  pod-console-logging  virtual
finer-leech    cy3dtr  pod-console-logging  virtual
free-mouse     gxtbq4  pod-console-logging  virtual
humble-bunny   srqnnb  pod-console-logging  virtual
wanted-muskox  ekw7fh  pod-console-logging  virtual
one-boa        by477d  pod-console-logging  virtual
great-urchin   srnx4g  pod-console-logging  virtual
ace-frog       g6arwg  pod-console-logging  virtual  barbar  farquar  new_tag
alive-marlin   gbwnfb  pod-console-logging  virtual
picked-parrot  am77wn  pod-console-logging  virtual
tough-kit      ke3wc7  pod-console-logging  virtual
legal-whale    8nq3mt  pod-console-logging  virtual
game-sponge    76pdc6  pod-console-logging  virtual
fun-ghoul      qxfm7k  pod-console-logging  virtual
aware-earwig   8m8hs7  pod-console-logging  virtual
chief-crane    7fapx7  pod-console-logging  virtual
select-tapir   4ascbr  pod-console-logging  virtual
on-slug        snfs8d  pod-console-logging  virtual
polite-llama   dbqd4m  pod-console-logging  virtual
frank-coyote   wcmk48  pod-console-logging  virtual
usable-condor  ed8hmy  pod-console-logging  virtual
still-imp      h6ra6d  pod-console-logging  virtual
Remove machine tags from a machine
For example:
    "added": 0,
    "removed": 1
Adding and removing machine tags simultaneously from multiple machines
    "added": 2,
    "removed": 1
| @tsv' | column -t
golden-martin  8fxery  pod-console-logging  virtual  barbar
one-boa        by477d  pod-console-logging  virtual  barbar
ace-frog       g6arwg  pod-console-logging  virtual  farquar
List machine tags for all machines
For example:
| @tsv' | column -t
For example:
| @tsv' | column -t
Work with virtual machine host tags
Discover your virtual machine host ID
maas $PROFILE vmhosts read \
| @tsv' | column -t
For example:
maas admin vmhosts read \
| @tsv' | column -t
vm_host_name      id
my-lxd-vm-host-1  1
Assign tags to a virtual machine host
maas $PROFILE vmhost add-tag $VMHOST_ID	tag=$TAG_NAME
If it worked, this should return Success, followed by the JSON that describes the VM host. You can check your work by listing all VM host tags.
Remove tags from a virtual machine host
List tags for all virtual machine hosts
For example:
vm_host_name      id  tags
my-lxd-vm-host-1  1   morkopongo  pod-console-logging  virtual
View tags for one virtual machine host
| @tsv' | column -t
name              id  tags
Work with region controller tags
Discover the ID of your region controller(s)
| jq -r '(["name","id"]
| @tsv' | column -t
For example:
| @tsv' | column -t
name                         id
bill-Lenovo-Yoga-C740-15IML  86xya8
Assign tags to a region controller
For example:
    "added": 1,
    "removed": 0
Remove tags from a region controller
For example:
    "added": 0,
    "removed": 1
List tags for all region controllers
For example:
hostname                     sysid   tags
bill-Lenovo-Yoga-C740-15IML  86xya8  virtual  lxd-vm-host
View tags for one region controller
If you need to find the ID of your region controller(s), you can [look it up](#heading--discover-the-id-of-your-region-controllers).
For example:
```bash
| @tsv' | column -t
hostname                     sysid   tags
Work with rack controller tags
Discover the ID of your rack controller(s)
| @tsv' | column -t
For example:
| @tsv' | column -t
name                         id
Assign tags to a rack controller
For example:
    "added": 1,
    "removed": 0
Remove tags from a rack controller
For example:
    "added": 0,
    "removed": 1
List tags for all rack controllers
For example:
hostname                     sysid   tags
View tags for one rack controller
For example:
```bash
| @tsv' | column -t
hostname                     sysid   tags
Work with block device tags
Discover the ID of your block device
| @tsv' | column -t
For example:
| @tsv' | column -t
system_id  block_device_id  path                    avail_size
qk4b3g     10               /dev/disk/by-dname/sda  0
The path component is printed to help you confirm that you are choosing the right block device, when there are several present. The avail-size column will tell you whether you can operate on that block device at all: If the available size is “0,” for example, you can’t set a block device tag on any part of that drive. Instead, you’d want to see something like this:
xn8taa     8                /dev/disk/by-dname/sda  1996488704
Assign tags to a block device
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the block device.
Not Found
Remove tags from a block device
For example:
Note that if you try to remove a tag from a block device that is not available, that is, to a block device that is in use, you will get a result like this:
Not Found
List tags for all block devices
For example:
id  tags
8   hello  ssd  trinkoplinko
View tags for one block device
For example:
id  tags
9   20gig  ssd
10  250Gs  ssd
Work with partition tags
Discover the ID of your partition
|@tsv' | column -t
For example:
|@tsv' | column -t
system_id  block_dev_id  part_id  path
xn8taa     8             67       /dev/disk/by-dname/sda-part1
The path component is printed to help you confirm that you are choosing the right partition, when there are several present.
Assign tags to a partition
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the partition.
Not Found
Remove tags from a partition
For example:
Note that if you try to remove a tag from a partition that is not available, that is, to a partition that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the partition you’ve chosen, MAAS will simply return Success, followed by a JSON sequence describing the current state of the partition.
List tags for all partitions
| @tsv' | column -t
For example:
| @tsv' | column -t
id  tags
54  farquar swap opendisk
67  foobar  farquar
97  foobar
View tags for one partition
To view tags for one partition, enter a command similar to this:
For example:
This command should produce output similar to this:
id  tags
67  foobar  farquar
Work with network tags
Discover the ID of your network interface
|@tsv'| column -t
For example:
|@tsv'| column -t
mac_address        type      id  tags
00:16:3e:18:7f:ee  physical  9   andrpko  plinko  cochise
Assign tags to a network interface
For example:
Remove tags from a network interface
For example:
List tags for all network interfaces
|@tsv'| column -t
For example:
|@tsv'| column -t
00:16:3e:18:7f:ee  physical  9   andrpko  plinko  cochise  farquar
View tags for one network interface
|@tsv'| column -t
For example:
|@tsv'| column -t
Work with device tags
Identify your devices
You can use a command similar to the following to identify your devices:
maas $PROFILE devices read \
|@tsv' | column -t
For example:
maas admin devices read \
|@tsv' | column -t
This command produces a result similar to the following:
hostname     system_id
better-sole  t8pmrs
light-aphid  76b6tt
Assign tags to a device
To assign tags to a device, you can use a command of the following form:
For example:
maas admin tag update-nodes farquar add=t8pmrs
A successful command like this might produce output similar to this:
    "added": 1,
    "removed": 0
You can also check your work by listing tags for all devices.
Remove tags from a device
To remove tags from a device, you can use a command of the following form:
For example:
maas admin tag update-nodes farquar remove=t8pmrs
    "added": 0,
    "removed": 1
List tags for all devices
If you want to list tags for all devices, you could use a command similar to this one:
| jq -r '(["hostname","system_id","tags"]
|@tsv' | column -t
For example:
|@tsv' | column -t
Such a command would produce output that looks something like this:
hostname     system_id  tags
better-sole  t8pmrs     farquar
light-aphid  76b6tt
View tags for one device
You can view the tags for a single device with the command:
maas $PROFILE device read $SYSTEM_ID \
|@tsv' | column -t
If you need to know the system ID of your device, you can look it up.
Note that this command differs in that (1) it uses the singular “device” instead of “devices;” (2) it gives the system ID of a specific device; and (3) it uses the single-record form of the jq tag list ("([.hostname,.system_id,.tag_names[]]", rather than “(.[]|[.hostname…”).
For example:
maas admin device read t8pmrs \
|@tsv' | column -t
Sample output might look like this:
Work with node tags
Identify your nodes
If you need to identify the system ID of your nodes, you can do so with a command like this one:
maas $PROFILE nodes read \
|@tsv'|column -t
For example:
When listing nodes, you should expect a large output, similar to this or larger:
hostname                     system_id
better-sole                  t8pmrs
light-aphid                  76b6tt
divine-stork                 8b3ypp
casual-prawn                 4end6r
driven-teal                  tgaat6
good-osprey                  napfxk
smart-hen                    c4rwq7
boss-satyr                   xn8taa
crack-guinea                 qk4b3g
finer-leech                  cy3dtr
free-mouse                   gxtbq4
humble-bunny                 srqnnb
one-boa                      by477d
great-urchin                 srnx4g
ace-frog                     g6arwg
alive-marlin                 gbwnfb
tough-kit                    ke3wc7
legal-whale                  8nq3mt
game-sponge                  76pdc6
fun-ghoul                    qxfm7k
aware-earwig                 8m8hs7
chief-crane                  7fapx7
select-tapir                 4ascbr
on-slug                      snfs8d
polite-llama                 dbqd4m
frank-coyote                 wcmk48
still-imp                    h6ra6d
A node listing will show all the machines, controllers, and devices in the system.
Assign tags to a node
To assign tags to any node (regardless of its type), you can use a command of this form:
‘’‘bash
For example,
For example:
    "added": 1,
    "removed": 0
Remove tags from a node
To remove tags from a node, regardless of type, you can use a command like this one:
For example:
    "added": 0,
    "removed": 1
List tags for all nodes
If you want to list tags for all nodes, you could use a command similar to this one:
|@tsv' | column -t
For example:
maas admin nodes read \
|@tsv' | column -t
light-aphid                  76b6tt
bill-Lenovo-Yoga-C740-15IML  86xya8     lxd-vm-host
View tags for one node
You could use a command with a form like this to view the tags for one node:
maas $PROFILE node read $SYSTEM_ID \
|@tsv' | column -t
For example:
maas admin node read xn8taa \
|@tsv' | column -t
This command produces output that looks something like this:
Work with annotations
Work with static annotations
Identify your machines
maas $PROFILE machines read \
|@tsv' | column -t
For example:
maas admin machines read \
|@tsv' | column -t
hostname       system_id
divine-stork   8b3ypp
casual-prawn   4end6r
driven-teal    tgaat6
good-osprey    napfxk
smart-hen      c4rwq7
boss-satyr     xn8taa
crack-guinea   qk4b3g
finer-leech    cy3dtr
free-mouse     gxtbq4
humble-bunny   srqnnb
one-boa        by477d
great-urchin   srnx4g
ace-frog       g6arwg
alive-marlin   gbwnfb
tough-kit      ke3wc7
legal-whale    8nq3mt
game-sponge    76pdc6
fun-ghoul      qxfm7k
aware-earwig   8m8hs7
chief-crane    7fapx7
select-tapir   4ascbr
on-slug        snfs8d
polite-llama   dbqd4m
frank-coyote   wcmk48
still-imp      h6ra6d
Set a static annotation for a machine
For example:
Change or clear a static annotation for a machine
List static annotations for all machines
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname       system_id  description
driven-teal    tgaat6     tango-golf
humble-bunny   srqnnb     sierra-romeo
tough-kit      ke3wc7     kilo-echo
View a static annotation for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
Identify machines that can receive dynamic annotations
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname       system_id  status
divine-stork   8b3ypp     Deployed
casual-prawn   4end6r     Ready
driven-teal    tgaat6     Allocated
immune-beetle  43xand     Allocated
good-osprey    napfxk     Allocated
smart-hen      c4rwq7     Allocated
boss-satyr     xn8taa     Ready
golden-martin  8fxery     Allocated
crack-guinea   qk4b3g     Allocated
finer-leech    cy3dtr     Deployed
free-mouse     gxtbq4     Allocated
humble-bunny   srqnnb     Allocated
wanted-muskox  ekw7fh     Deployed
one-boa        by477d     Allocated
great-urchin   srnx4g     Allocated
ace-frog       g6arwg     Ready
alive-marlin   gbwnfb     Deployed
picked-parrot  am77wn     Allocated
tough-kit      ke3wc7     Deployed
legal-whale    8nq3mt     Allocated
game-sponge    76pdc6     Allocated
fun-ghoul      qxfm7k     Allocated
aware-earwig   8m8hs7     Deployed
chief-crane    7fapx7     Ready
select-tapir   4ascbr     Allocated
on-slug        snfs8d     Allocated
polite-llama   dbqd4m     Allocated
frank-coyote   wcmk48     Allocated
usable-condor  ed8hmy     Deployed
still-imp      h6ra6d     Allocated
Set dynamic annotations for a machine
Dynamic annotations, otherwise known as “workload annotations” or “owner data,” can be used to keep track of the runtime status of machines that are acquired or deployed. These annotations are set using key=value pairs. You can set any key=value pair that you wish for any machine, although it’s probably more useful if you standardise your key names.
For example:
Clear and change dynamic annotations for a machine
You can change dynamic annotations for a machine simply by executing a new set-owner-data command:
You can clear a dynamic annotation by entering the empty string ("") as the $VALUE:
List dynamic annotations for all machines
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname       system_id  owner_data
divine-stork   8b3ypp
casual-prawn   4end6r
driven-teal    tgaat6     farquar     foobar
good-osprey    napfxk
smart-hen      c4rwq7
List dynamic allocations for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
