MAAS logging (deb/2.7/UI)
Five questions you may have:
  1. What is the syslog logging path?
  2. How do I use a remote syslog server?
  3. What are commissioning logs?
  4. What are test logs?
  5. What are event logs?
  6. What are audit event logs?
The syslog logging path
Syslog data is kept in /var/log/maas/rsyslog/<machine-name><yyyy-mm-dd>/messages. Every machine known to MAAS will have corresponding syslogs.
Using a remote syslog server
