MAAS logging reference (snap/3.0/UI)
Five questions you may have:
  1. What is the syslog logging path?
  2. How do I use a remote syslog server?
  3. What are commissioning logs?
  4. What are test logs?
  5. What are event logs?
The syslog logging path
Syslog data is kept in /var/snap/maas/common/log/rsyslog/<machine-name><yyyy-mm-dd>/messages. Every machine known to MAAS will have corresponding syslogs.
Syslog data is kept in /var/log/maas/rsyslog/<machine-name><yyyy-mm-dd>/messages. Every machine known to MAAS will have corresponding syslogs.
Using a remote syslog server
For example:
