Five questions you may have:
- What is the syslog logging path?
- How do I use a remote syslog server?
- What are commissioning logs?
- What are test logs?
The syslog logging path
Syslog data is kept in /var/snap/maas/common/log/rsyslog/<machine-name><yyyy-mm-dd>/messages
. Every machine known to MAAS will have corresponding syslogs.
Using a remote syslog server
For example, to set your syslog server to 192.168.100.11
If you clear the remote_syslog
value, MAAS will revert to the default behaviour, which is to send all syslog information to all MAAS region controllers.
For example:
