How to install MAAS(deb/2.9/UI)
About installing MAAS
MAAS can be installed in either of two configurations: test or production. The test configuration uses a small PostgreSQL database (in a separate snap), designed for use with MAAS. The full-up production configuration uses a separate PostgreSQL database for performance and scalability.
MAAS is relatively easy to install and configure using Debian packages.
MAAS initialisation modes reference
rack X Rack controller only
About SSH keys
MAAS uses your Launchpad or Github SSH keys to access machines that have been deployed. Normally, you enter this key during the initialisation of MAAS. If you don’t have a key associated with either of these services, you will have an opportunity to paste your public key into the MAAS SSH key list, after you’ve started MAAS for the first time as part of the welcome screens.
About the MAAS URL
About the shared secret
How to install MAAS
This article will show you:
How to check system requirements for MAAS
Before installing MAAS for the first time, you should make sure that the target system meets the minimum requirements for the machines that run MAAS, which vary widely depending on local implementation and usage. Below, you will find resource estimates based on MAAS components and operating system (Ubuntu Server). We consider both a test configuration (for proof of concept) and a production environment.
PostgreSQL 512 0.5 5
Rack controller 512 0.5 5
PostgreSQL 2048 2.0 20
Rack controller 2048 2.0 20
Please see the release notes, as directed above, to install MAAS 3.2 Beta.
How to upgrade from an earlier snap version to MAAS 3.1
If you want to upgrade from a earlier snap version to the 3.1 snap, and you are using a region+rack configuration, use this command:
$ sudo snap refresh --channel=3.1/stable maas
After entering your password, the snap will refresh from the 3.1 channel. You will not need to re-initialise MAAS.
How to do a fresh snap install of MAAS 3.1
To install MAAS 3.1 from a snap, simply enter the following:
$ sudo snap install --channel=3.1/stable maas
After entering your password, the snap will download and install from the 3.1 channel.
How to ugprade from MAAS 3.0 to MAAS 3.1
To upgrade from MAAS 3.0 to MAAS 3.1:
  1. Back up your MAAS server completely; the tools and media are left entirely to your discretion. Just be sure that you can definitely restore your previous configuration, should this procedure fail to work correctly.
  2. Add the MAAS 3.1 PPA to your repository list with the following command, ignoring any apparent error messages:
sudo apt-add-repository ppa:maas/3.1
  1. Run the MAAS upgrade like this:
sudo apt update
sudo apt upgrade maas
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.1 release.
  2. If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.1.
How to upgrade from 2.8 or lower to MAAS 3.1
If you are running MAAS 2.8 or lower, you can upgrade directly to MAAS 3.1. You must first make sure that the target system is running Ubuntu 20.04 LTS or higher, by executing the following command:
lsb_release -a
Distributor ID:	Ubuntu
Description:	Ubuntu xx.yy
Release:	xx.yy
Codename:	$RELEASE_NAME
The minimum “xx.yy” required for MAAS 3.0 is “20.04,” code-named “focal.”
If you are currently running Ubuntu bionic 18.04 LTS, you can upgrade to focal 20.04 LTS with the following procedure:
  1. Upgrade the release:
  1. Accept the defaults for any questions asked by the upgrade script.
  2. Reboot the machine when requested.
  3. Check whether the upgrade was successful:
lsb_release -a
Description:	Ubuntu 20.04(.nn) LTS
Release:	20.04
Codename:	focal
If you’re upgrading from MAAS version 2.8 or lower to version 3.1: While the following procedures should work, note that they are untested. Use at your own risk. Start by making a verifiable backup; see step 1, below.
  1. Run the release upgrade like this, answering any questions with the given default values:
  1. Check whether your upgrade has been successful by entering:
lsb_release -a
No LSB modules are available.
Release:	20.04
Codename:	focal
How to do a fresh install of MAAS 3.1 from packages
The recommended way to set up an initial MAAS environment is to put everything on one machine:
sudo apt update
sudo apt-get -y install maas
Executing this command leads you to a list of dependent packages to be installed, and a summary prompt that lets you choose whether to continue with the install:
Choosing “Y” proceeds with a standard apt package install.
Distributed environment
and the rack controller on another:
sudo maas-rack register
These two steps will lead you through two similar apt install sequences.
How to upgrade from an earlier snap version to MAAS 3.0
If you want to upgrade from a earlier snap version to the 3.0 snap, and you are using a region+rack configuration, use this command:
$ sudo snap refresh --channel=3.0/stable maas
After entering your password, the snap will refresh from the 3.0 channel. You will not need to re-initialise MAAS.
How to do a fresh snap install of MAAS 3.0
To install MAAS 3.0 from a snap, simply enter the following:
$ sudo snap install --channel=3.0/stable maas
After entering your password, the snap will download and install from the 3.0 stable channel.
How to ugprade from MAAS 2.9 to MAAS 3.0
  2. Add the MAAS 3.0 PPA to your repository list with the following command, ignoring any apparent error messages:
sudo apt-add-repository ppa:maas/3.0
sudo apt update
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.0 release.
  2. If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.0.
How to upgrade from 2.8 or lower to MAAS 3.0
If you are running MAAS 2.8 or lower, you must also make sure that the target system is running Ubuntu 20.04 LTS or higher, by executing the following command:
lsb_release -a
Release:	xx.yy
lsb_release -a
Release:	20.04
Codename:	focal
If you’re upgrading from MAAS version 2.8 or lower to version 3.0: While the following procedures should work, note that they are untested. Use at your own risk. Start by making a verifiable backup; see step 1, below.
lsb_release -a
Release:	20.04
Codename:	focal
How to do a fresh install of MAAS 3.0 from packages
sudo apt update
How to upgrade from an earlier snap version to MAAS 2.9
If you want to upgrade from a earlier snap version to the 2.9 snap, and you are using a region+rack configuration, use this command:
How to do a fresh snap install of MAAS 2.9
To install MAAS 2.9 from a snap, simply enter the following:
$ sudo snap install --channel=2.9/stable maas
After entering your password, the snap will download and install from the 2.9 stable channel.
How to upgrade from MAAS 2.8 or lower to MAAS 2.9
MAAS 2.8 is the last supported version for Ubuntu 18.04 LTS. Newer versions of MAAS will not be back-portable, and consequently, to upgrade to MAAS 2.9 and all future versions, you will also need to upgrade the base operating system to Ubuntu 20.04. You do these two operations all at once, with the following procedure:
sudo add-apt-repository ppa:maas/2.9
You will get a message similar to this:
 For stable releases of 2.9.x
 More info: https://launchpad.net/~maas/+archive/ubuntu/2.9
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:2 http://ppa.launchpad.net/maas/2.8/ubuntu bionic InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Ign:5 http://ppa.launchpad.net/maas/2.9/ubuntu bionic InRelease
Hit:6 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Err:7 http://ppa.launchpad.net/maas/2.9/ubuntu bionic Release
  404  Not Found [IP: 91.189.95.85 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/maas/2.9/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
This message seems to indicate that nothing happened, but, in fact, this command still creates the file:
/etc/apt/sources.list.d/maas-ubuntu-2_9-bionic.list
This file identifies the path to the 2.9 PPA, even though it incorrectly implies there’s a Bionic release there:
deb http://ppa.launchpad.net/maas/2.9/ubuntu bionic main
Still, that’s enough for do-release-upgrade to figure out that there is a 2.9 PPA, and when it checks, it will find a Focal version of MAAS, which it will bring over and install in place of 2.8. It isn’t necessary to stop MAAS or do anything else, except go ahead and run the upgrade:
This command will produce a lot of output, ask you a few questions (for which the defaults are usually fine), and eventually ask you to reboot. Once your machine has come back up, you can check whether your upgrade has been successful by entering:
lsb_release -a
Description:	Ubuntu 20.04.1 LTS
Release:	20.04
Codename:	focal
You have now upgraded to the Ubuntu 20.04 LTS base, and if you check your running MAAS install, you should see that the version has been updated to the latest stable 2.9 release.
How to do a fresh install of MAAS 2.9 from packages
How to initialise MAAS for a test or POC environment
You can initialise MAAS as a compact version for testing. To achieve this, we provide a separate snap, called maas-test-db, which contains a PostgreSQL database for use in testing and evaluating MAAS. The following instructions will help you take advantage of this test configuration.
$ sudo maas init --help
optional arguments:
run modes:
    sudo maas init region+rack --database-uri maas-test-db:-#,
$ sudo maas-test-db.psql
psql (12.4)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb, owned by maas. Note that this database is still empty because MAAS is not yet initialised and, hence, is not yet using the database. Once this is done, you can run the maas init command:
MAAS has been set up.
  sudo maas configauth
  sudo maas createadmin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
  1. You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
     sudo apt update -y
  2. You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where $MAAS_DBUSER is your desired database username, and $MAAS_DBPASS is the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.
     sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'"
  3. Create the MAAS database with the following command, where $MAAS_DBNAME is your desired name for the MAAS database (typically known as maas). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.
     sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME"
  4. Edit /etc/postgresql/10/main/pg_hba.conf and add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than 0/0.
  5. You can then initialise MAAS via the following command:
How to create a MAAS user
You will need to create a MAAS administrator user to access the web UI:
$PROFILE is the administrative MAAS username you wish to create. $EMAIL_ADDRESS is an email address you may type in at random (currently, MAAS does not use this email address).
The createadmin option will ask for an SSH key. If you have an SSH key associated with your launchpad or github accounts, you can enter the username here to use the associated key. For launchpad, just enter lp:username, and for github, enter gh:username at the prompt. In both cases, the actual username has to be supplied after the lp: or gh: prefix.
How to check the status of MAAS services
sudo maas status
How to re-initialise MAAS
How to list additional MAAS initialisation options
How to configure MAAS
maas admin --help
MAAS CLI help, sample output usage: maas admin [-h] COMMAND ...
Issue commands to the MAAS region controller at http://192.168.43.251:5240/MAAS/api/2.0/.
optional arguments:
drill down:
COMMAND
boot-source-selection
boot-source-selections
commissioning-script
commissioning-scripts
dnsresource-records
TXT)
domain Manage domain.
domains Manage domains.
fabric Manage fabric.
fabrics Manage fabrics.
iprange Manage IP range.
ipranges Manage IP ranges.
maas Manage the MAAS server.
network Manage a network.
networks Manage the networks.
node-script-results
MAAS.
package-repositories
MAAS.
pod Manage an individual pod.
Disks) on a machine.
MAAS.
sshkey Manage an SSH key.
MAAS.
sslkey Manage an SSL key.
space Manage space.
spaces Manage spaces.
subnet Manage subnet.
subnets Manage subnets.
nodes.
user Manage a user account.
zone Manage a physical zone.
zones Manage physical zones.
Configuration
  1. Setting upstream DNS
  2. Importing an SSH key for your admin user
  3. Importing images
  4. Configuring DNS
How to set upstream DNS
How to set up SSH for the admin user
How to import images
grub-efi-signed/uefi        amd64/generic
grub-efi/uefi           arm64/generic
pxelinux/pxe            i386/generic
ubuntu/bionic           amd64/ga-18.04
ubuntu/bionic           amd64/ga-18.04-lowlatency
ubuntu/bionic           amd64/hwe-18.04
ubuntu/bionic           amd64/hwe-18.04-edge
ubuntu/bionic           amd64/hwe-18.04-lowlatency
ubuntu/bionic           amd64/hwe-18.04-lowlatency-edge
    "os": "ubuntu",
    "release": "trusty",
    "arches": [
        "amd64"
    "subarches": [
    "labels": [
    "boot_source_id": 1,
    "id": 2,
How to enable DHCP
"fabric_id": $FABRIC_ID,
$RACK_CONTR_HOSTNAME
    "subnet": {
        "name": "192.168.123.0/24",
        "description": "",
        "vlan": {
            "vid": 0,
            "mtu": 1500,
            "dhcp_on": false,
            "external_dhcp": null,
            "relay_vlan": null,
            "fabric": "fabric-2",
            "primary_rack": null,
            "name": "untagged",
            "id": 5003,
            "space": "undefined",
            "secondary_rack": null,
            "fabric_id": 2,
        "cidr": "192.168.123.0/24",
        "rdns_mode": 2,
        "gateway_ip": null,
        "dns_servers": [],
        "allow_dns": true,
        "allow_proxy": true,
        "active_discovery": false,
        "managed": true,
        "id": 4,
    "type": "dynamic",
    "end_ip": "192.168.123.253",
    "user": {
        "is_superuser": true,
        "username": "admin",
        "email": "admin@admin.com",
        "is_local": true,
    "comment": "",
    "id": 1,
maas $PROFILE vlan update $FABRIC_ID untagged dhcp_on=True primary_rack=$RACK_CONTR_HOSTNAME
    "vid": 0,
    "mtu": 1500,
    "dhcp_on": true,
    "relay_vlan": null,
    "primary_rack": "8dwnne",
    "name": "untagged",
    "fabric_id": 2,
    "id": 5003,
http://${API_HOST}:5240/MAAS
Configuration
lp:<username>
gh:<username>
How to enable DHCP
About network discovery
sudo do-release-upgrade --allow-third-parties
Should be (?)
gack. @g-ubuntuone-e, you’re right. thanks. :slight_smile:
@billwear just ran into the same thing, the doc hasn’t been updated for --allow-third-party, can you fix it?
