Note that all headings are hyperlinks that can be bookmarked.
Prepare for MAAS installation
You should take the following steps before installing MAAS for the first time on a new system:
Make sure that the target system meets the minimum hardware requirements.
Make sure you understand how support works currently, for MAAS 2.7.
- Make sure you uninstall bind9, if it’s running on your system:
a. Check to see if bind9
is running:
ps aux | grep named
b. If bind9 is running, remove it with the following command:
sudo apt-get remove --auto-remove bind9
Install and verify MAAS
This section explains how to:
Install MAAS
The following command will give you a clean install of MAAS 2.7:
sudo snap install maas --channel=2.7
MAAS must be initialised prior to use.
Initialise MAAS
To initialise MAAS with a run mode:
- use the
maas init
command with the specified –mode argumentregion
,rack
, orregion+rack
sudo maas init --mode region+rack
- Answer the prompts in the dialog that appears:
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
If you enter a Launchpad or GitHub account name with associated SSH key, MAAS will import them automatically.
The MAAS URL sets the API address of one or more controllers. You will use the username and password to access the web UI.
Some modes will additionally ask for a shared secret that will allow the new rack controller to register with the region controller.
Re-initialise MAAS
To re-initialise MAAS, use the following command:
Verify MAAS installation
After a snap installation of MAAS, you can verify that the installation was successful with the following command:
sudo maas config
This command should return a sequence similar to the following if MAAS is operating propery:
Mode: region+rack
Settings:
maas_url=http://192.168.122.1:5240/MAAS
Check service statuses
sudo maas status
Sample output should look something like this:
bind9 RUNNING pid 7999, uptime 0:09:17
dhcpd STOPPED Not started
dhcpd6 STOPPED Not started
ntp RUNNING pid 8598, uptime 0:05:42
postgresql RUNNING pid 8001, uptime 0:09:17
proxy STOPPED Not started
rackd RUNNING pid 8000, uptime 0:09:17
regiond:regiond-0 RUNNING pid 8003, uptime 0:09:17
regiond:regiond-1 RUNNING pid 8008, uptime 0:09:17
regiond:regiond-2 RUNNING pid 8005, uptime 0:09:17
regiond:regiond-3 RUNNING pid 8015, uptime 0:09:17
tgt RUNNING pid 8040, uptime 0:09:15
Reinitialising MAAS
It is also possible to re-initialise MAAS to switch modes. For example, to switch from rack
to region
sudo maas init region
The MAAS command takes additional init
options; see the MAAS installation technical reference for details.
snap-3-0-ui snap-3-0-cli -->
How to configure MAAS
Replace $PROFILE with whatever username you set during the createadmin
part of the install process. Next, login with the following command:
Substitute $MAAS_URL with the URL that was returned to you when you initialised MAAS, for example, 192.168.43.251:5240/MAAS
. Remember that, once you’ve logged in, you can get extensive CLI help with the command:
maas admin --help
MAAS CLI help, sample output
usage: maas admin [-h] COMMAND ...Issue commands to the MAAS region controller at http://192.168.43.251:5240/MAAS/api/2.0/.
optional arguments:
drill down:
COMMAND
boot-source-selection
boot-source-selections
commissioning-script
commissioning-scripts
dnsresource-records
TXT)
domain Manage domain.
domains Manage domains.
fabric Manage fabric.
fabrics Manage fabrics.
iprange Manage IP range.
ipranges Manage IP ranges.
maas Manage the MAAS server.
network Manage a network.
networks Manage the networks.
node-script-results
MAAS.
package-repositories
MAAS.
pod Manage an individual pod.
Disks) on a machine.
MAAS.
sshkey Manage an SSH key.
MAAS.
sslkey Manage an SSL key.
space Manage space.
spaces Manage spaces.
subnet Manage subnet.
subnets Manage subnets.
nodes.
user Manage a user account.
zone Manage a physical zone.
zones Manage physical zones.
Configuration
- Setting upstream DNS
- Importing an SSH key for your admin user
- Importing images
- Configuring DNS
Setting DNS
Importing images
grub-efi-signed/uefi amd64/generic
grub-efi/uefi arm64/generic
pxelinux/pxe i386/generic
ubuntu/bionic amd64/ga-18.04
ubuntu/bionic amd64/ga-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04
ubuntu/bionic amd64/hwe-18.04-edge
ubuntu/bionic amd64/hwe-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04-lowlatency-edge
"os": "ubuntu",
"release": "trusty",
"arches": [
"amd64"
"subarches": [
"labels": [
"boot_source_id": 1,
"id": 2,
Enabling DHCP
"fabric_id": $FABRIC_ID,
$RACK_CONTR_HOSTNAME
"subnet": {
"name": "192.168.123.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"external_dhcp": null,
"relay_vlan": null,
"fabric": "fabric-2",
"primary_rack": null,
"name": "untagged",
"id": 5003,
"space": "undefined",
"secondary_rack": null,
"fabric_id": 2,
"cidr": "192.168.123.0/24",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": false,
"managed": true,
"id": 4,
"type": "dynamic",
"end_ip": "192.168.123.253",
"user": {
"is_superuser": true,
"username": "admin",
"email": "admin@admin.com",
"is_local": true,
"comment": "",
"id": 1,
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"primary_rack": "8dwnne",
"name": "untagged",
"fabric_id": 2,
"id": 5003,
