About installing MAAS
MAAS can be installed in either of two configurations: test or production. The test configuration uses a small PostgreSQL database (in a separate snap), designed for use with MAAS. The full-up production configuration uses a separate PostgreSQL database for performance and scalability.
MAAS initialisation modes
Mode | Region | Rack | Database | Description |
region |
X | Region API server only | ||
rack |
X | Rack controller only | ||
region+rack |
X | X | Region API server and rack controller | |
none |
Reinitialises MAAS and stops services |
SSH keys
MAAS uses your Launchpad or Github SSH keys to access machines that have been deployed. Normally, you enter this key during the initialisation of MAAS. If you don’t have a key associated with either of these services, you will have an opportunity to paste your public key into the MAAS SSH key list, after you’ve started MAAS for the first time as part of the welcome screens.
MAAS URL
All run modes (except none
) prompt for a MAAS URL, interpreted differently depending on the mode:
region
: Used to create a new region controller. -
rack
: Used to locate the region controller.
Shared secret
How to install MAAS
This article will show you:
- How to check system requirements for MAAS
- How to upgrade from an earlier snap version to MAAS 2.9
- How to do a fresh snap install of MAAS 2.9
- How to initialise MAAS for a test or POC environment
- How to initialise MAAS for a production configuration
- How to check the status of MAAS services
- How to re-initialise MAAS
- How to list additional MAAS initialisation options
- How to configure MAAS
Note that all headings are hyperlinks for bookmarking.
Before installing MAAS for the first time, you should make sure that the target system meets the minimum hardware requirements.
If you want to upgrade from a earlier snap version to the 2.9 snap, and you are using a region+rack
configuration, use this command:
$ sudo snap refresh --channel=3.0/stable maas
After entering your password, the snap will refresh from the 3.0 channel. You will not need to re-initialise MAAS.
To install MAAS 2.9 from a snap, simply enter the following:
$ sudo snap install --channel=2.9/stable maas
After entering your password, the snap will download and install from the 2.9 stable channel.
You can initialise MAAS as a compact version for testing. To achieve this, we provide a separate snap, called maas-test-db
, which contains a PostgreSQL database for use in testing and evaluating MAAS. The following instructions will help you take advantage of this test configuration.
Once MAAS is installed, you can use the --help
flag with maas init
to get relevant instructions:
$ sudo maas init --help
optional arguments:
run modes:
region+rack Both region and rack controllers
region Region controller only
rack Rack controller only
We’ll quickly walk through these instructions to confirm your understanding. First, install the maas-test-db
snap:
$ maas-test-db.psql
psql (10.6)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb
, owned by maas
. Note that this database is still empty because MAAS is not yet initialised and, hence, is not yet using the database. Once this is done, you can run the maas init
command:
MAAS has been set up.
sudo maas configauth
sudo maas createadmin
Let’s assume you just want a local testing user named admin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
At this point, MAAS is basically set up and running. You can confirm this with sudo maas status
. If you need an API key, you can obtain this with sudo maas apikey --username yourusername
. Now you will be able to test and evaluate MAAS by going to the URL you entered or accepted above and entering your admin
username and password.
You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
sudo apt update -y sudo apt install -y postgresql
You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where
$MAAS_DBUSER
is your desired database username, and$MAAS_DBPASS
is the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'"
Create the MAAS database with the following command, where
$MAAS_DBNAME
is your desired name for the MAAS database (typically known asmaas
). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME"
Edit
/etc/postgresql/10/main/pg_hba.conf
and add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than0/0
.host $MAAS_DBNAME $MAAS_DBUSER 0/0 md5
You can then initialise MAAS via the following command:
You should use localhost
for $HOSTNAME
if you’re running PostgreSQL on the same box as MAAS.
sudo maas status
bind9 RUNNING pid 7999, uptime 0:09:17
dhcpd STOPPED Not started
dhcpd6 STOPPED Not started
ntp RUNNING pid 8598, uptime 0:05:42
postgresql RUNNING pid 8001, uptime 0:09:17
proxy STOPPED Not started
rackd RUNNING pid 8000, uptime 0:09:17
regiond:regiond-0 RUNNING pid 8003, uptime 0:09:17
regiond:regiond-1 RUNNING pid 8008, uptime 0:09:17
regiond:regiond-2 RUNNING pid 8005, uptime 0:09:17
regiond:regiond-3 RUNNING pid 8015, uptime 0:09:17
tgt RUNNING pid 8040, uptime 0:09:15
It is also possible to re-initialise MAAS to switch modes. For example, to switch from rack
to region
The init
command can takes optional arguments. To list them, as well as read a brief description of each, you can enter:
http://${API_HOST}:5240/MAAS
Configuration
Your main concerns for this experiment are the DNS forwarder, the Ubuntu image import section, and the SSH public key, though you might want to set the region name to something memorable, since this text will appear at the bottom of every MAAS screen in this install domain. Set the DNS forwarder to something obvious, e.g., 8.8.8.8
, Google’s DNS server. Set this to your own internal DNS server if you know the IP address.
lp:<username>
gh:<username>
If you want to use your existing public key from your home directory, you can select “Upload”and then copy your entire public key from .ssh/id_rsa.pub
(or wherever you may have stored the key):
Enabling DHCP
Networking
