MAAS installation (snap/3.0/UI)
2.7 2.8 2.9 3.0
  1. Prepare for MAAS installation
  2. Install and verify MAAS
  3. Configure MAAS
Note that all headings are hyperlinks that can be bookmarked.
You should take the following steps before installing MAAS for the first time on a new system:
  1. Make sure that the target system meets the minimum hardware requirements.
  2. Make sure you understand how support works for the chosen version.
  3. Make sure you uninstall bind9, if it’s running on your system:
a. Check to see if bind9 is running:
ps aux | grep named
b. If bind9 is running, remove it with the following command:
sudo apt-get remove --auto-remove bind9
This section explains how to:
MAAS can be installed in either of two configurations: test or production. These two configurations, along with MAAS install requirements and initialisation modes, are discussed in the MAAS installation technical reference. This section provides step-by-step instructions for installing both configurations. If you prefer a more in-depth presentation with extended explanations, try the MAAS installation tutorial.
This section will show how to:
  1. Remove bind9, if installed
  2. Install the MAAS 3.0 Beta snap
  3. Upgrade the 2.9 snap to the MAAS 3.0 Beta
  4. Initialise MAAS for a test rig or proof-of-concept
  5. Initialise MAAS for production
  6. Check the service status of MAAS
  7. Re-initialise MAAS
Installing MAAS from the snap
For more information on snaps, see the Snapcraft documentation.
To install MAAS from a snap, simply enter the following:
$ sudo snap install --channel=3.0/beta maas
After entering your password, the snap will download and install from the 3.0 beta channel. rMAAS will need to be initialised before first use.
Upgrading MAAS from 2.9
If you want to upgrade from a 2.9 snap to 3.0 Beta 1 snap, and you are using a region+rack configuration, use this command:
$ sudo snap refresh --channel=3.0/beta maas
After entering your password, the snap will refresh from the 3.0 beta channel. You will not need to re-initialise MAAS.
Initialising MAAS as a test configuration
$ sudo maas init --help
optional arguments:
run modes:
$ maas-test-db.psql
psql (10.6)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb, owned by maas. Note that this database is still empty because MAAS is not yet initialised and, hence, is not yet using the database. Once this is done, you can run the maas init command:
MAAS has been set up.
  sudo maas configauth
  sudo maas createadmin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
Configuration verification
After a snap installation of MAAS, you can verify the currently-running configuration with:
sudo maas config
  1. You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
     sudo apt update -y
  2. You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where $MAAS_DBUSER is your desired database username, and $MAAS_DBPASS is the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.
     sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'"
  3. Create the MAAS database with the following command, where $MAAS_DBNAME is your desired name for the MAAS database (typically known as maas). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.
     sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME"
  4. Edit /etc/postgresql/10/main/pg_hba.conf and add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than 0/0.
  5. You can then initialise MAAS via the following command:
Checking MAAS service status
sudo maas status
Reinitialising MAAS
The MAAS command takes additional init options; see the MAAS installation technical reference for details.
How to configure MAAS
http://${API_HOST}:5240/MAAS
Configuration
lp:<username>
gh:<username>
Enabling DHCP
Networking
