2.7 | 2.8 | 2.9 | 3.0 | |
- Determine the minimum hardware requirements for MAAS
- Install MAAS in various configurations and verify your work
- Configure your MAAS installation and get it running
All of the headings in this page are anchored and linked, so that you can bookmark them. Feel free to use these headings to customize your own bookmark folder on your browser toolbar: this may save you time working with MAAS later.
MAAS hardware requirements
Two questions you might have about hardware requirements:
- What are the requirements for a test environment?
- What are the requirements for a production environment?
Memory (MB) | CPU (GHz) | Disk (GB) | |
Region controller (minus PostgreSQL) | 512 | 0.5 | 5 |
PostgreSQL | 512 | 0.5 | 5 |
Rack controller | 512 | 0.5 | 5 |
Ubuntu Server (including logs) | 512 | 0.5 | 5 |
Here is a production scenario designed to handle a high number of sustained client connections. This scenario implements both high availability (region and rack) and load balancing (region). MAAS reserves extra space for images (database and rack controller), while some images, such as those for Microsoft Windows, may require a lot more â so plan accordingly.
Region controller (minus PostgreSQL) | 2048 | 2.0 | 5 |
PostgreSQL | 2048 | 2.0 | 20 |
Rack controller | 2048 | 2.0 | 20 |
- the number of connecting clients (client activity)
- how you decide to distribute services
- whether or not you use high availability/load balancing.
- the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
How to install MAAS
Upgrade MAAS 2.8 to MAAS 2.9
MAAS 2.8 is the last supported version for Ubuntu 18.04 LTS. Newer versions of MAAS will not be back-portable, and consequently, to upgrade to MAAS 2.9 and all future versions, you will also need to upgrade the base operating system to Ubuntu 20.04. You do these two operations all at once, with the following procedure:
sudo add-apt-repository ppa:maas/2.9
You will get a message similar to this:
For stable releases of 2.9.x
More info: https://launchpad.net/~maas/+archive/ubuntu/2.9
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:2 http://ppa.launchpad.net/maas/2.8/ubuntu bionic InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Ign:5 http://ppa.launchpad.net/maas/2.9/ubuntu bionic InRelease
Hit:6 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Err:7 http://ppa.launchpad.net/maas/2.9/ubuntu bionic Release
404 Not Found [IP: 91.189.95.85 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/maas/2.9/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
This message seems to indicate that nothing happened, but, in fact, this command still creates the file:
/etc/apt/sources.list.d/maas-ubuntu-2_9-bionic.list
This file identifies the path to the 2.9 PPA, even though it incorrectly implies thereâs a Bionic release there:
deb http://ppa.launchpad.net/maas/2.9/ubuntu bionic main
Still, thatâs enough for do-release-upgrade
to figure out that there is a 2.9 PPA, and when it checks, it will find a Focal version of MAAS, which it will bring over and install in place of 2.8. It isnât necessary to stop MAAS or do anything else, except go ahead and run the upgrade:
sudo do-release-upgrade --allow-third-parties
This command will produce a lot of output, ask you a few questions (for which the defaults are usually fine), and eventually ask you to reboot. Once your machine has come back up, you can check whether your upgrade has been successful by entering:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.1 LTS
Release: 20.04
Codename: focal
You have now upgraded to the Ubuntu 20.04 LTS base, and if you check your running MAAS install, you should see that the version has been updated to the latest stable 2.9 release.
Installing MAAS 2.9 fresh
The recommended way to set up an initial MAAS environment is to put everything on one machine:
sudo apt-get -y install maas
Executing this command leads you to a list of dependent packages to be installed, and a summary prompt that lets you choose whether to continue with the install:
Choosing âYâ proceeds with a standard apt
package install.
Distributed environment
and the rack controller (see Rack controller for details) on another:
sudo maas-rack register
These two steps will lead you through two similar apt
install sequences.
Creating a MAAS user
Finally, you will need to create a MAAS administrator user to access the web UI:
For example, the process might go like this:
The username can be anything. You will also be prompted to supply a password for the user. The command option --password=$PASSWORD
can be used to specify one but, depending on your environment, this may pose a security risk.
At this time, MAAS does not make use of the email address. However, it may do so in the future.
Finally, the createadmin
option asks for an SSH key:
If you have an SSH key associated with your launchpad or github accounts, you can enter the username here to include the key. For launchpad, just enter lp:username
, and for github, enter gh:username
at the prompt. In both cases, the actual username has to be supplied after the lp:
or gh:
prefix.
If you don't have a key associated with either of these services, you will have an opportunity to paste your public key into the MAAS SSH key list, after you've started MAAS for the first time as part of the welcome screens.
Next steps
Once you have installed your MAAS environment (region + rack controller) and any possible extra rack controllers(s), you are ready to begin your Configuration journey.
How to configure MAAS
Once youâve successfully installed MAAS (regardless of method), you can login to the MAAS CLI via the following process. First, generate the API-key for the user youâre going to employing:
Replace $PROFILE with whatever username you set during the createadmin
part of the install process. Next, login with the following command:
Substitute $MAAS_URL with the URL that was returned to you when you initialised MAAS, for example, 192.168.43.251:5240/MAAS
. Remember that, once youâve logged in, you can get extensive CLI help with the command:
maas admin --help
MAAS CLI help, sample output
usage: maas admin [-h] COMMAND ...Issue commands to the MAAS region controller at http://192.168.43.251:5240/MAAS/api/2.0/.
optional arguments:
drill down:
COMMAND
boot-source-selection
boot-source-selections
commissioning-script
commissioning-scripts
dnsresource-records
TXT)
domain Manage domain.
domains Manage domains.
fabric Manage fabric.
fabrics Manage fabrics.
iprange Manage IP range.
ipranges Manage IP ranges.
interface Manage a nodeâs or deviceâs interface.
maas Manage the MAAS server.
network Manage a network.
networks Manage the networks.
node-script-results
MAAS.
package-repositories
MAAS.
pod Manage an individual pod.
Disks) on a machine.
MAAS.
sshkey Manage an SSH key.
MAAS.
sslkey Manage an SSL key.
space Manage space.
spaces Manage spaces.
subnet Manage subnet.
subnets Manage subnets.
nodes.
user Manage a user account.
zone Manage a physical zone.
zones Manage physical zones.
The command information you see here comes from the region serverâs
have changed, use the commandâs ârefreshâ sub-command to fetch the
Configuration
- Setting upstream DNS
- Importing an SSH key for your admin user
- Importing images
- Configuring DNS
Setting DNS
After logging in for the first time, you will need to set a number of system-wide configuration options. First up, you should configure DNS. You can check out the help for DNS settings, known in the CLI as a âDNS forwarderâ:
Here, weâve set the DNS forwarder to â8.8.8.8â (Google), which is a reliable value.
Importing images
Before going any further, itâs worthwhile to start the image import, as it can sometimes take a few minutes. You can see what images you already have downloaded with this command:
grub-efi-signed/uefi amd64/generic
grub-efi/uefi arm64/generic
pxelinux/pxe i386/generic
ubuntu/bionic amd64/ga-18.04
ubuntu/bionic amd64/ga-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04
ubuntu/bionic amd64/hwe-18.04-edge
ubuntu/bionic amd64/hwe-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04-lowlatency-edge
Suppose you also want a version called âTrustyâ â you can import a new image by first selecting it for download, like this:
"os": "ubuntu",
"release": "trusty",
"arches": [
"amd64"
"subarches": [
"labels": [
"boot_source_id": 1,
"id": 2,
Enabling DHCP
Once your image has been imported, youâll want to get DHCP working, which means finding the untagged VLAN. In truth, it shouldnât be too hard, because at this point, there still should only be one.
In order to turn on DHCP, you need to know two things besides the VLAN name (âuntaggedâ): the fabric ID and the primary rack controller name. To start, all the fabrics will be on the same untagged VLAN, so any fabric will do. You can find a valid fabric ID by reading it from any subnet, so just pick one (e.g., 192.168.123.0/24) and find a usable fabric ID like this:
"fabric_id": $FABRIC_ID,
Next, find the name of the primary rack controller. Itâs usually fairly obvious, but for purposes of argument, assume that itâs not known. You can get it this way:
This returns a hostname, which weâll call:
$RACK_CONTR_HOSTNAME
"subnet": {
"name": "192.168.123.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"external_dhcp": null,
"relay_vlan": null,
"fabric": "fabric-2",
"primary_rack": null,
"name": "untagged",
"id": 5003,
"space": "undefined",
"secondary_rack": null,
"fabric_id": 2,
"cidr": "192.168.123.0/24",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": false,
"managed": true,
"id": 4,
"type": "dynamic",
"end_ip": "192.168.123.253",
"user": {
"is_superuser": true,
"username": "admin",
"email": "admin@admin.com",
"is_local": true,
"comment": "",
"id": 1,
If youâve done everything correctly, you should see JSON output similar to this sample:
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"primary_rack": "8dwnne",
"name": "untagged",
"fabric_id": 2,
"id": 5003,
- subnet has the traditional meaning: a range of IP addresses covering a subset of IP addresses. Generally speaking , a subnet is a collection of IP addresses which includes at least two addresses.
- a space is a collection of subnets that you can create with MAAS, understanding that each subnet can belong to only one space. Spaces allow multiple subnets to communicate without requiring a direct network path between them.
- a zone is also an ad-hoc collection, but one which groups individual nodes, rather than subnets. MAAS allows you to create and edit zones at will.
- a fabric is essentially a collection of trunked switches, allowing you to access a group of VLANs.
VM hosts can give you greater control over your hardware. A VM host is a collection of individual virtual machines. You can use a VM host to compose machines into an abstraction of resources that functions like a physical machine â without building one!
