maas-agent 3.6.0 crashes if using external DHCP server
ok- so i installed 3.6 using apt. can I still move to snap. Or should I just to a fresh install and redeploy?
You should be able to migrate to snap by extracting the current database uri with
#!/bin/bash
conf_file="/etc/maas/regiond.conf"
db_user=$(sudo grep '^database_user:' "$conf_file" | awk '{print $2}')
db_pass=$(sudo grep '^database_pass:' "$conf_file" | awk '{print $2}')
db_host=$(sudo grep '^database_host:' "$conf_file" | awk '{print $2}')
db_port=$(sudo grep '^database_port:' "$conf_file" | awk '{print $2}')
db_name=$(sudo grep '^database_name:' "$conf_file" | awk '{print $2}')
db_uri="postgres://${db_user}:${db_pass}@${db_host}:${db_port}/${db_name}"
echo "$db_uri"
and note it somewhere. Then you remove the MAAS debs entirely with
sudo DEBIAN_FRONTEND=noninteractive apt remove --purge -y 'maas*' && sudo DEBIAN_FRONTEND=noninteractive apt -y autoremove
and then you
sudo snap install --channel=3.6/edge maas
sudo maas init region+rack --database-uri "<THE DB URI YOU EXTRACTED BEFORE>"
