KVM Pod Networking
The purpose of this document is to give users some insight into some of the steps carried out when testing KVM Pod networking functionality that was introduced in the 18.10 product cycle for MAAS.
Setting up MAAS in LXD Container with Libvirt
For testing the KVM Pod networking functionality to its full extent we will need to setup a LXD container where we will host MAAS and libvirt. For more details on how to do this, please see Setting up a Flexible "Virtual MAAS" Test Environment
Creating KVM Pod
There are several ways you can create a KVM Pod to get up and started. Some of this is documented in other places within the MAAS documentation but is either briefly contained here or linked to for convenience.
Creating KVM Pod with UI
To create a KVM Pod with the UI
Creating KVM Pod with API
To create a KVM Pod with the API/CLI
Creating KVM Pod with python-libmaas
To create a KVM Pod with python-libmaas follow these steps
Here is an example:
$ bin/maas shell
Welcome to the MAAS shell.
In [1]: from maas.client import login
In [2]: client = login("http://10.0.0.2:5240/MAAS/", username="admin", password="test")
In [3]: pod = client.pods.create(type="virsh", power_address="qemu+ssh://ubuntu@10.0.0.2/system", power_pass="ubuntu")
Updating KVM Pod Host and Default MACVLAN Mode
There are three new additions to MAAS for KVM Pod networking. The first two are Pod specific; the Pod’s host and default MACVLAN mode. These two optional settings can be configured in the UI, API/CLI, and with python-libmaas. Let’s take a look at the different ways to update them and their associated expected outputs.
Updating Pod host and default_macvlan_mode with UI
TODO (this portion has not been implemented yet).
Updating Pod host and default_macvlan_mode with API
Updating the Pod’s host and default_macvlan_mode settings with valid input will succeed:
# maas admin pod update 11 host="gdehta" default_macvlan_mode="private"
"total": {
"cores": 8,
"memory": 15918,
"local_storage": 88341741568
"host": {
"system_id": "gdehta",
"__incomplete__": true
"id": 11,
"pool": {
"name": "default",
"id": 0,
"default_macvlan_mode": "private",
"zone": {
"name": "default",
"description": "",
"id": 1,
"architectures": [
"amd64/generic"
"name": "holy-jay",
"type": "virsh",
"used": {
"cores": 3,
"memory": 3072,
"local_storage": 24000000000
"available": {
"cores": 5,
"memory": 12846,
"local_storage": 64341741568
"storage_pools": [
"id": "77bf9255-e2f6-4f94-80ef-459cabd966e5",
"name": "default",
"type": "dir",
"path": "/var/lib/libvirt/images",
"total": 88341741568,
"used": 24000000000,
"available": 64341741568,
"default": true
"tags": [
"virtual"
"cpu_over_commit_ratio": 1.0,
"capabilities": [
"composable",
"dynamic_local_storage",
"over_commit",
"storage_pools"
"resource_uri": "/MAAS/api/2.0/pods/11/"
As we can see the Pod’s host and default_macvlan_mode were both updated correctly.
Additionally, we can set these Pod settings to empty strings:
# maas admin pod update 11 host="" default_macvlan_mode=""
"total": {
"cores": 8,
"memory": 15918,
"tags": [
"virtual"
"available": {
"cores": 5,
"memory": 12846,
"id": 11,
"default_macvlan_mode": "",
"type": "virsh",
"capabilities": [
"composable",
"over_commit",
"storage_pools"
"zone": {
"name": "default",
"description": "",
"id": 1,
"host": {
"system_id": null,
"used": {
"cores": 3,
"memory": 3072,
"architectures": [
"amd64/generic"
"pool": {
"name": "default",
"id": 0,
"storage_pools": [
"name": "default",
"type": "dir",
"default": true
"name": "holy-jay",
It should be noted that the default for default_macvlan_mode is “bridge” when it is set to null or the empty string.
Invalid input for these will result in an error as one would expect:
# maas admin pod update 11 host="yodel" default_macvlan_mode="lady-who"
{"default_macvlan_mode": ["Select a valid choice. lady-who is not one of the available choices."], "host": ["Select a valid choice. yodel is not one of the available choices."]}
Updating Pod host and default_macvlan_mode with python-libmaas
TODO - this portion is waiting on this bug to be fixed.
Once this issue is resolved we will be able to update pod.host and show the expected output.
Here is an example of just updating default_macvlan_mode:
$ bin/maas shell
In [3]: pod = client.pods.list()[0]
In [4]: pod.default_macvlan_mode
Out[4]: ''
In [5]: pod.default_macvlan_mode = "vepa"
In [6]: pod.save()
In [7]:
Composing Machines with Interface Constraints
There are three new additions to MAAS for KVM Pod networking. The first two were done in the previous section. The last one is being able to specify interface constraints while composing machines. These interface constraints can be configured in the UI, API/CLI, and with python-libmaas.
Composing Machines with UI
TODO - UI still needs to be implemented to show this
Composing Machines with API
Composing machines with valid interface constraints:
# maas admin pod compose 11 interfaces="eth0:subnet=10.0.0.0/24"
"system_id": "tse88m",
"resource_uri": "/MAAS/api/2.0/machines/tse88m/"
Composing machines with invalid interface constraints:
# maas admin pod compose 11 interfaces="eth0:subnet=19.0.0.0/24"
This pod does not match the specified networks.
Composing Machines with python-libmaas
$ bin/maas shell
In [4]: pod.compose(interfaces="eth1:subnet=10.0.0.0/24")
Out[4]: {'system_id': 'wcfw4q', 'resource_uri': '/MAAS/api/2.0/machines/wcfw4q/'}
In [5]:
In [5]: pod.compose(interfaces="eth1:subnet=19.0.0.0/24")
CallError Traceback (most recent call last)
<ipython-input-5-782f139f5cc9> in <module>()
----> 1 pod.compose(interfaces="eth1:subnet=19.0.0.0/24")
~/code/canonical/python-libmaas/maas/client/utils/async.py in wrapper(*args, **kwargs)
47 if not eventloop.is_running():
48 while isawaitable(result):
---> 49 result = eventloop.run_until_complete(result)
50 return result
51
/usr/lib/python3.6/asyncio/base_events.py in run_until_complete(self, future)
466 raise RuntimeError('Event loop stopped before Future completed.')
467
--> 468 return future.result()
469
470 def stop(self):
~/code/canonical/python-libmaas/maas/client/viscera/pods.py in compose(self, cores, memory, cpu_speed, architecture, storage, hostname, domain, zone, interfaces)
231 "zone must be an int, str or Zone, not %s" %
232 type(zone).__name__)
--> 233 return await self._handler.compose(**params, id=self.id)
234
235 async def delete(self):
~/code/canonical/python-libmaas/maas/client/bones/__init__.py in __call__(self, **data)
300 if key.startswith('_'):
301 data[key[1:]] = data.pop(key)
--> 302 response = await self.bind(**params).call(**data)
303 return response.data
304
~/code/canonical/python-libmaas/maas/client/bones/__init__.py in dispatch(self, uri, body, headers)
461 "uri": uri,
462 }
--> 463 raise CallError(request, response, content, self)
464
465 # Decode from JSON if that's what it's declared as.
CallError: POST http://10.0.0.2:5240/MAAS/api/2.0/pods/11/?op=compose -> HTTP 400 Bad Request (This pod does not match the specified networks.)
