Three questions you may have:
- How do I create an IP range?
- How do I edit an existing IP range?
- How do I delete an existing IP range?
Create a range
Edit a range
To edit an IP range, first find the ID of the desired IP range with the command:
maas admin ipranges read
Examine the JSON output to find the ID corresponding to the IP range you want to edit, then enter:
maas admin iprange update $ID start_ip="<start ip>" end_ip="<end ip>" comment="freeform comment"
This command will update the IP range associated with $ID.
