About images (deb/2.9/UI)
Four questions you may have:
  1. What are boot sources, and why do they matter?
  2. How do I select and import an image?
  3. How do I set up and use a local image mirror?
  4. How do I use and manage VMWare images?
MAAS stores images in the region controller’s database, from where the rack controller proxies them to the individual machines. It’s important to note that for ESXi images, network configuration includes only these five parameters:
  1. DHCP
  2. Static/auto IP assignments
  3. Aliases
  4. VLANs
  5. Bonds
  1. balance-rr – portid
  2. active-backup – explicit
  3. 802.3ad – iphash, LACP rate and XMIT hash policy settings ignored
Boot sources
https://images.maas.io/ephemeral-v3/stable/
