How to manage racks (deb/2.9/CLI)
This article will tell you:
How to install a rack controller
sudo snap install maas
sudo maas init rack --maas-url $MAAS_URL --secret $SECRET
The $SECRET is stored in file /var/lib/maas/secret on the API server.
sudo maas-rack register --url $MAAS_URL --secret $SECRET
Note that on the UI, you can find complete instructions for adding a rack controller under the “Controllers” tab. Simply click on the button labelled, “Add rack controller” and choose the instructions relevant to your build model (snap or packages). The commands there will already include the correct MAAS URL and secret, so you can cut and paste them at the command line.
How to list rack controllers
You can also list and confirm all registered rack controllers via the CLI; select the link at the top of the page to find out how. Note that you will need multiple rack controllers to achieve specific high availability configurations.
You can also list and confirm all registered rack controllers:
How to unregister a rack controller
About the potential dangers of moving a rack controller
  • Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behaviour. It is not a supported configuration.
How to move a rack controller from one MAAS instance to another
where the secret is found in /var/lib/maas/secret.
About moving a rack controller from one MAAS instance to another
In the course of normal operations, you may wish to move a device acting as a rack controller from one MAAS instance to another. From the point of view of MAAS, there is no such action as moving a rack controller, although you can delete a rack controller from one MAAS and reinstantiate the same controller (binary-wise) on another MAAS instance. From your perspective, of course, you are moving one box performing rack controller functions, either physically or network-wise, from one MAAS to another.
How to move the controller
To move a rack controller using the MAAS UI, first, delete the rack controller. In the “Controllers” tab in the UI, select the rack controller you with to delete, choose “Take action” and select “Delete.” You will be asked to confirm with a red button, entitled “Delete 1 controller.”
