How to manage DHCP (snap/2.9/UI)
This article will tell you:
How to enable MAAS-managed DHCP
  1. Under the ‘Take action’ button select ‘Provide DHCP’. A new window will appear.
  2. Select the primary rack controller. For DHCP HA, select both the primary and the secondary.
  3. Create a reserved, dynamic IP range. Fill in the fields ‘Dynamic range start IP’ and ‘Dynamic range end IP’.
  4. Apply your changes with the ‘Provide DHCP’ button.
You will also need to set a default gateway:
How to resolve IP conflicts
In some cases, MAAS manages a subnet that is not empty, which could result in MAAS assigning a duplicate IP address. MAAS is capable of detecting IPs in use on a subnet. Be aware that there are two caveats:
  1. If a previously-assigned NIC is in a quiescent state or turned off, MAAS may not detect it before duplicating an IP address.
2/ At least one rack controller must have access to the IP-assigned machine in order for this feature to work.
How to extend a reserved dynamic IP range
How to configure external DHCP
How to use a DHCP relay
  1. Ensure the target VLAN has DHCP enabled.
  2. Set up the external relay. This relay is set up independently from MAAS. See DHCP relay for software suggestions.
  1. Configure MAAS-managed DHCP. Navigate to the source VLAN page and select the ‘Relay DHCP’ action. Fill in the fields in the resulting form. The crucial setting is the target VLAN (‘Relay VLAN’). Press the ‘Relay DHCP’ button to finish.
  1. To relay DHCP traffic for a VLAN (source) through another VLAN (target):
How to customise MAAS with DHCP snippets
When MAAS manages DHCP, you customise it through the use of DHCP snippets. These are user-defined configuration options that can be applied either globally, per subnet, or per machine. You apply a global snippet to all VLANs, subnets, and machines. All three types end up in /var/snap/maas/common/maas/dhcpd.conf or /var/snap/maas/common/maas/dhcpd6.conf. Be aware that if you edit these files directly, you will need to sudo to root, as there is no maas user in the snap (all relevant files are owned by root). For information on what options to use, refer to the dhcpd.conf man page.
To create a global snippet:
    global_snippet=true
To create a subnet snippet:
    subnet=$SUBNET_ID
To create a node snippet:
    node=$NODE_ID
How to list DHCP snippets
To list a specific snippet:
How to update a DHCP snippet
Update a snippet attribute:
How to enable or disable a DHCP snippet
How to delete a DHCP snippet
To delete a snippet:
How to set DNS parameters
It is possible to set DNS parameters using the MAAS CLI, using the following instructions.
How to create an A or AAAA record in DNS
How to create an alias (CNAME) record in DNS
How to create a Mail Exchange pointer record in DNS
How to set a DNS forwarder
To set a DNS forwarder:
Hi
  • The above shown image is from 2.6 and it is not what I see in 2.9,
  • The steps for enabling DHCP aren’t what they are in 2.9, due to I’m not able to even find the “Enable DHCP” button or anything similar,
when I’ve issued below commands:
sudo snap install maas --channel=2.9/stable
sudo maas init region+rack --maas-url http://10.0.0.2:5240/MAAS --database-uri maas-test-db:///
sudo maas createadmin --username admin --password ubuntu --email admin@example.com --ssh-import lp:<unsername>
/Henrik
