How to install MAAS
It seems to have worked for me by just eliminating the entire offending argument. Like this…
sudo maas init region+rack --database-uri “postgres://$MAAS_DBUSER:$MAAS_DBPASS@$HOSTNAME/$MAAS_DBNAME”
Whether this leaves MAAS unlinked to a DB, I’m not sure but I was able to login to the web gui. The command without the argument will automatically run through the admincreate script, unless switched off. I also noticed when trying to install 3.4 from deb, there is no command in the man pages for the offending argument. When I attempted to use the db name “maasdb” it errored out and said it already existed on a fresh attempt. Does 3.4 autocreate the postgresql during apt install of MAAS? I’m currently testing how it works if I manually upgrade postgresql to v14 and pre-create the DB. I’m hoping the MAAS install sees it and uses it by default with the db name “maasdb.”
Two things:
  • after editing pg_hba.conf I had to sudo service postgresql restart otherwise maas init failed
  • I’m stuck on maas $PROFILE subnet read $SUBNET_CIDR | grep fabric_id since there is no explanation of how to set SUBNET_CIDR
thanks for spotting the issue @rgarcia2009 !
In the meantime, you can list the existing subnets with maas $PROFILE subnets read and extract the CIDR of the subnet you want
I think for
  1. Import your selected image(s):
it should be (for consistency)
*Would have made the edit, but discourse wouldn’t let me
@billwear, the command for creating an admin user as in step 5 didn’t work for me. Seems like createadmin should be one word.
Thank you!
