How to import images (deb/3.0/UI)
MAAS is only useful once it has images available to provision its nodes. Therefore, one key post-install task is to select and import images from the boot source. Once MAAS imports images, it will update them on an hourly basis, via a default sync mechanism. This page explains how to select and import the images that MAAS requires to provision its nodes.
Three questions you may have:
  1. How do I import standard images from maas.io?
  2. How do I use other image mirrors to download images?
  3. How do I import and provision non-Ubuntu images?
Note that it is possible to build your own images in a limited sense: see MAAS Image Builder.
Importing images from maas.io
The ‘Images’ page shows what images and architectures have been selected and downloaded. By default, MAAS will automatically grab the most recent Ubuntu LTS releases (and amd64 architecture). Below, we have selected two additional releases:
You can tell MAAS to sync images hourly, at the region level, using a toggle switch in the top-right corner of the screen. See Boot image sources) for more details. We highly recommended syncing images hourly. Syncing at the rack controller level (from regiond) occurs every 5 min and cannot be disabled.
Click the ‘Save selection’ button to initiate the import. MAAS will present existing images along with the newly-selected ones. The latter will have their status updated as the import is processed:
To remove an image, un-select it and click ‘Save selection’.
Image mirrors
You can also host Ubuntu images on a mirror. Configure this mirror by selecting ‘Custom’ beneath ‘Choose source’. Enter the mirror URL and click ‘Connect’.
Advanced options, such as using a GPG key or keyring to validate the mirror path (snap installation location: /snap/maas/current/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg), are revealed by clicking ‘Show advanced options’:
Other images
It is also possible to import and provision images other than Ubuntu. Images supported and provided by MAAS will appear beneath the ‘Other Images’ section. Currently, images for CentOS 6.6, CentOS 7.0, and CentOS 8.0 are available. These images can be imported and used just like the Ubuntu images above.
You can tell MAAS to sync images hourly, at the region level. See Boot image sources) for more details. We highly recommended syncing images hourly. Syncing at the rack controller level (from regiond) occurs every 5 min and cannot be disabled.
Eight questions you may have:
  1. How do I get started with the MAAS CLI?
  2. How do I list boot sources?
  3. How do I select images?
  4. How do I list image selections?
  5. How do I import newly-selected images?
  6. How do I list currently available images?
  7. How do I delete a boot source?
  8. How do I edit a boot source?
List boot sources
Select images
    subarches="*" labels="*"
Hardware enablement (HWE)
    subarches="hwe-x" labels="*"
List image selections
Import newly-selected images
Delete a boot source
Edit a boot source
Update the boot source:
Add a boot source
The general syntax is:
Using a local image mirror
  1. URL=https://$MIRROR/maas/images/ephemeral-v3/stable/
  2. KEYRING_FILE=/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg
  1. URL=https://images.maas.io/ephemeral-v3/stable/
