How to customise machines (deb/3.0/UI)
MAAS machines can be customised in a number of ways, including:
  • machine storage.
  • commissioning and deployment configurations (known as “pre-seeding”).
  • custom Ubuntu kernels.
  • kernel boot options.
  • resource pools.
In this article, you can learn:
In short, this article will explain these possible customisations, and provide detailed instructions on how to customise your own machines as desired.
About customising machines
In this section, you’ll learn:
About customising machine storage
About UEFI booting
About block devices
Physical
Virtual
About partitions
About storage restrictions
About VMFS datastores
About disk erasure
About disk erasure types
  1. Standard erasure - Overwrites all data with zeros.
  2. Secure erasure - Although effectively equivalent to Standard erase, Secure erase is much faster because the disk’s firmware performs the operation. Because of this, however, some disks may not be able to perform this erasure type (SCSI, SAS, and FC disks in particular).
  3. Quick erasure - Same as Standard erase but only targets the first 1 MB and the last 1 MB of each disk. This removes the partition tables and/or superblock from the disk, making data recovery difficult but not impossible.
It is very important to pay close attention to your selections when erasing disks.
About pre-seeding
During machine enlistment, deployment, commissioning and machine installation, MAAS sends Tempita-derived configuration files to the cloud-init process running on the target machine. MAAS refers to this process as preseeding. These preseed files are used to configure a machine’s ephemeral and installation environments and can be modified or augmented to a custom machine configuration.
Preseeding in MAAS can be achieved in two ways:
  1. Curtin, a preseeding system similar to Kickstart or d-i (Debian Installer), applies customisation during operating system (OS) image installation. MAAS performs these changes on deployment, during OS installation, but before the machine reboots into the installed OS. Curtin customisations are perfect for administrators who want their deployments to have identical setups all the time, every time. This blog post contains an excellent high-level overview of custom MAAS installs using Curtin.
  2. Cloud-init, a system for setting up machines immediately after instantiation. cloud-init applies customisations after the first boot, when MAAS changes a machine’s status to ‘Deployed.’ Customisations are per-instance, meaning that user-supplied scripts must be re-specified on redeployment. Cloud-init customisations are the best way for MAAS users to customise their deployments, similar to how the various cloud services prepare VMs when launching instances.
About templates
The Tempita template files are found in the /var/snap/maas/current/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
The Tempita template files are found in the /etc/maas/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
Phase Filename prefix
Enlistment enlist
Commissioning commissioning
Installation curtin (Curtin)
The enlist template, for example, contains only minimal variables, whereas enlist_userdata includes both user variables and initialisation logic.
Tempita’s inheritance mechanism is the reverse of what you might expect. Inherited files, such as enlist_userdata, become the new template which can then reference variables from the higher-level file, such as enlist.
About template naming
Some earlier versions of MAAS only support Ubuntu. If the machine operating system is Ubuntu, then filenames without {os} will also be tried, to maintain backward compatibility.
  1. {prefix}_{os}_{node_arch}_{node_subarch}_{release}_{node_name} or {prefix}_{node_arch}_{node_subarch}_{release}_{node_name}
  2. {prefix}_{os}_{node_arch}_{node_subarch}_{release} or {prefix}_{node_arch}_{node_subarch}_{release}
  3. {prefix}_{os}_{node_arch}_{node_subarch} or {prefix}_{node_arch}_{node_subarch}
  4. {prefix}_{os}_{node_arch} or {prefix}_{node_arch}
  5. {prefix}_{os}
  6. {prefix}
  7. generic
The prefix can be either enlist, enlist_userdata, commissioning, curtin, curtin_userdata or preseed_master. Alternatively, you can omit the prefix and the following underscore.
For example, to create a generic configuration template for Ubuntu 16.04 Xenial running on an x64 architecture, the file would need to be called ubuntu_amd64_generic_xenial_node.
To create the equivalent template for curtin_userdata, the file would be called curtin_userdata_ubuntu_amd64_generic_xenial_node.
About Ubuntu kernels
  4. Low latency kernels
About low latency kernels
About choosing a kernel
About kernel boot options
MAAS can specify kernel boot options to machines on both a global basis (UI and CLI) and a per-machine basis (CLI-only). A full catalogue of available options can be found in the Linux kernel parameters list at kernel.org.
About resource pools
Administrators can manage resource pools on the Machines page in the web UI, under the Resource pools tab, or with the MAAS CLI. Also note that all MAAS installations have a resource pool named “default.” MAAS automatically adds new machines to the default resource pool.
If you want to customise machines, you may want to know:
How to customise machine storage
This section will show you:
Note that layouts can be set globally and on a per-machine basis. For additional information on storage layouts, see the Storage layouts reference section at the end of this article.
How to erase disks
and not:
How to list block devices
Output:
        "id": 10,
        "serial": "",
        "block_size": 4096,
        "available_size": 0,
        "filesystem": null,
        "id_path": "/dev/vda",
        "size": 5368709120,
        "model": "",
        "type": "physical",
        "uuid": null,
        "used_size": 5365563392,
        "partitions": [
                "bootable": false,
                "id": 9,
                "size": 5360320512,
                "type": "partition",
                "filesystem": {
                    "mount_options": null,
                    "label": null,
                    "fstype": "lvm-pv",
                    "mount_point": null
        "tags": [
            "rotary"
        "name": "vda"
        "id": 11,
        "serial": null,
        "block_size": 4096,
        "filesystem": {
            "label": "root",
            "fstype": "ext4",
            "mount_point": "/"
        "id_path": null,
        "size": 3221225472,
        "partition_table_type": null,
        "model": null,
        "type": "virtual",
        "used_size": 3221225472,
        "partitions": [],
        "tags": [],
        "name": "vgroot-lvroot"
How to read a block device
    "name": "vgroot-lvroot",
    "type": "virtual",
    "filesystem": {
        "mount_point": "/",
        "fstype": "ext4",
        "label": "root"
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to create a block device
    "name": "vdb",
    "used_for": "Unused",
    "type": "physical",
    "used_size": 0,
    "filesystem": null,
    "id_path": "",
    "id": 12,
    "block_size": 4096,
    "tags": [],
    "uuid": null,
    "serial": "QM00001",
    "partitions": [],
    "size": 21474836480,
    "model": "QEMU"
How to update a block device
    "block_size": 4096,
    "filesystem": null,
    "model": "QEMU",
    "name": "newroot",
    "partitions": [],
    "tags": [],
    "used_size": 0,
    "id_path": "",
    "uuid": null,
    "id": 12,
    "type": "physical",
    "serial": "QM00001"
How to delete a block device
How to format a block device
    "block_size": 4096,
    "size": 3221225472,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
        "mount_point": null
    "model": null,
    "partitions": [],
    "tags": [],
    "id_path": null,
    "id": 11,
    "type": "virtual",
    "serial": null
    "available_size": 3221225472,
    "type": "virtual",
    "used_size": 0,
    "filesystem": null,
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to mount a block device
    "type": "virtual",
    "filesystem": {
        "mount_point": "/srv",
        "mount_options": "",
        "fstype": "ext4",
        "label": ""
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to unmount a block device
    "type": "virtual",
    "filesystem": {
        "mount_point": null,
        "fstype": "ext4",
        "label": ""
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to list partitions
        "bootable": false,
        "id": 9,
        "resource_uri":
        "size": 5360320512,
        "filesystem": {
            "label": null,
            "fstype": "lvm-pv",
            "mount_point": null
How to create a partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
How to delete a partition
How to format a partition
    "id": 9,
    "size": 5360320512,
    "bootable": false,
    "filesystem": {
        "fstype": "ext4",
        "label": ""
How to unformat a partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
How to mount a partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
How to unmount a partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
        "mount_point": null
    "id": 3,
    "size": 2000003072
How to list VMFS datastores
        "human_size": "45.8 GB",
        "filesystem": {
            "fstype": "vmfs6",
        "name": "datastore1",
        "system_id": "4qxaga",
        "devices": [
                "size": 35026632704,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 5,
                "id": 71,
                "size": 10729029632,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 6,
                "id": 77,
        "id": 17,
        "size": 45755662336,
How to view a VMFS datastore
    "system_id": "b66fn6",
    "id": 18,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "2.8 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
    "size": 2814377984,
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "device_id": 1,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "id": 80,
    "name": "datastore42",
    "filesystem": {
        "fstype": "vmfs6",
    "id": 19,
    "size": 2814377984,
How to edit a VMFS datastore
    "id": 19,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "13.5 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
            "bootable": false,
            "tags": [],
            "id": 86,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 2,
    "size": 13543407616,
How to pre-seed with curtin
You can customise the Curtin installation by either editing the existing curtin_userdata template or by adding a custom file as described above.
Curtin provides hooks to execute custom code before and after installation takes place. These hooks are named early and late respectively, and they can both be overridden to execute the Curtin configuration in the ephemeral environment. Additionally, the late hook can be used to execute a configuration for a machine being installed, a state known as in-target.
This syntax won’t work because the value of sh's -c argument is itself an entire command. The correct way to express this is:
early_commands:
late_commands:
How to pre-seed with cloud-init
It’s easy to customise cloud-init via the web UI. When you’ve selected a machine and choose ‘Take action >> Deploy,’ you’ll be presented with the following screen:
Select a viable release (in this case, “Ubuntu 18.04…”) and check the box labelled “Cloud-init user-data…”:
Paste the desired script directly into the box, and select “Start deployment for machine.” For example, to import an SSH key immediately after your machine deployment, you could paste this script:
#!/bin/bash
echo === $date ===
ssh-import-id foobar_user
) | tee /ssh-key-import.log
No script validation of any kind is provided with this capability. You will need to test and debug your own cloud-init scripts.
Using cloud-init to customise a machine after deployment is relatively easy. After you’re logged in, use the following command to deploy a machine with a custom script you’ve written:
The three replaceable parameters shown above decode to:
  1. $PROFILE: Your MAAS login. E.g. admin
  2. $SYSTEM_ID: The machine’s system ID (see example below)
  3. <base-64-encoded-script>: A base-64 encoded copy of your customisation script. See below for an example.
E.g.:
Suppose you would like to import an SSH key immediately after your machine deployment. First, you want to find the machine’s system_id, which you can do with this short, command-line jq script:
maas admin machines read | jq -r '(["HOSTNAME","SYSID"] | (., map(length*"-"))),
You might then use this script, called import_key.sh, to retrieve the needed key:
#!/bin/bash
echo === $date ===
This script echos the date in addition to the output of the ssh-import-key command. It also adds that output to a file, /ssh-key-import.log.
Base-64 encoding is required because the MAAS command-line interacts with the MAAS API, and base-64 encoding allows MAAS to send the script inside a POST HTTP command.
Use the base64 command to output a base-64 encoded version of your script:
base64 -w0 ./import_key.sh
Putting it together:
maas $PROFILE machine deploy $SYSTEM_ID user_data=$(base64 -w0 ./import_key.sh)
After MAAS deploys the machine, you’ll find /ssh-key-import.log on the machine you deployed.
How to choose Ubuntu kernels
To set the default minimum enlistment and commissioning kernel (based on Ubuntu release: GA kernel) for all machines visit the ‘General’ tab of the ‘Settings’ page and select a kernel in the ‘Default Minimum Kernel Version’ field of the Commissioning section. Don’t forget to click ‘Save’.
To set the minimum deploy kernel on a machine basis, click on a machine from the ‘Machines’ page of the web UI and switch to its ‘Configuration’ page. Click ‘Edit’ in the ‘Machine configuration’ section, select a kernel in the ‘Minimum Kernel’ field followed by ‘Save changes’.
To set a specific kernel during deployment, select a machine from the ‘Machines’ page and choose ‘Deploy’ under ‘Take action’. Then choose a kernel from the (third) kernel field. Hit ‘Deploy machine’ to initiate the deployment.
MAAS verifies that the specified kernel is available for the given Ubuntu release (series) before deploying the machine.
How to set global kernel boot options
To set kernel boot options globally, as an admin, open the ‘Settings’ page and on the ‘General’ tab scroll down to the ‘Global Kernel Parameters’ section:
Type in the desired (space separated) options and click ‘Save’. The contents of the field will be used as-is. Do not use extra characters.
You can set kernel boot options and apply them to all machines with the CLI command:
maas $PROFILE maas set-config name=kernel_opts value='$KERNEL_OPTIONS'
See How can I set kernel boot options for a specific machine? to set per-machine kernel boot options.
How to use resource pools
This section will explain:
How to add a resource pool
How to delete a resource pool
How to add a machine to a resource pool
How to remove a machine from a resource pool
How to add a VM host to a resource pool
How to remove a VM host from a resource pool
How to create a resource pool
How to list available resource pools
How to list a single resource pool
How to update a resource pool
There are three layout types:
  1. Flat layout
  2. LVM layout
  3. bcache layout
Flat layout storage reference
sda - disk
sda2 rest of sda part ext4 /
LVM storage layout reference
sda - disk
lvroot rest of sda lvm ext4 /
vgroot rest of sda lvm
sda - disk
sdb (ssd) - disk
bcache0 per sda2 disk ext4 /
Name Size Type Use
sda - disk
sda1 3 MB part EFI
sda2 4 GB part Basic Data
sda4 - skipped
sda5 249 MB part Basic Data
sda6 249 MB part Basic Data
sda8 285 MB part Basic Data
