Three questions you may have:
- How do I upload hardware test scripts?
- How do I use tags to help with hardware test scripts?
- How do I view test results?
Uploading hardware test scripts
The optional filters argument lets you search for tags assigned to a script, such as using TAG=cpu
with the above example.
"history": [
"id": 40,
"comment": "Updated version"
"id": 34,
"comment": null
MAAS keeps a history of all uploaded script versions, allowing you to easily revert to a previous version using the id
of the version you wish to revert to:
To delete a script, use delete
Tags
Results
If you only want to see the latest or currently-running result, you can use current-commissioning
, current-testing
, or current-installation
instead of an id:
where $SUPPRESSED
is either True
or False
. The JSON formatted output to the above command will include ‘results’ dictionary with an entry for suppressed
"results": [
"id": 21,
"name": "smartctl-validate",
"status": 5,
"status_name": "Aborted",
"exit_status": null,
"runtime": "0:00:00",
"endtime": 1554238601.765214,
"parameters": {
"storage": {
"argument_format": "{path}",
"type": "storage",
"value": {
"id_path": "/dev/vda",
"model": "",
"name": "sda",
"physical_blockdevice_id": 1,
"serial": ""
"script_id": 1,
"script_revision_id": null,
"suppressed": true
$RUN_ID is labelled id
in the verbose result output.
