Error executing power command error="signal: killed"
I am using hp dl380 gen11, its getting commisioned, while deployment maas cant able to power on server, as it already created maas user in the server ILO, during commision also it power on server via ipmi, but cant power on during deployment. got the below error in logs
Error executing power command error=“signal: killed”
if anyone know the fix pls reply.
What MAAS version are you using?
I am using MaaS Version 3.6
can you try 3.6/edge ?
As it is already in production, this cant be changed though
You might check if this is the same symptom Bug #2112206 “Powerloop on HPE ProLiant DL385 and DL360 " : Bugs : MAAS
Hi @r00ta thanks for the help, this issue is fixed now
