About disk erasure (snap/3.0/UI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
About disk erasure types
  1. Standard erasure
  2. Secure erasure
  3. Quick erasure
Abot standard erasure
About secure eraseure
About quick erasure
