About disk erasure types
- Standard erasure
- Secure erasure
- Quick erasure
Abot standard erasure
About secure eraseure
About quick erasure
- Use ‘secure erase’ if the disk supports it
- If it does not then use ‘quick erase’
How to erase disks
and not:
Note the difference in singular and plural “machine/machines” in the commands. Releasing a machine requires that you have the system_id
of the machine to be released, which you can obtain with a command like this one:
Parameters secure_erase
and quick_erase
are both optional, although if you don’t specify either of them, the entire disk will be overwritten with null bytes. Note that this overwrite process is very slow.
