Once a machine has been commissioned (see Commission machines) the next logical step is to deploy it. Deploying a machine means, effectively, to install an operating system on it.
Two questions you may have:
MAAS also supports machine customisation with a process called “preseeding.” For more information about customising machines, see Custom machine setup.
Acquire
Acquiring (“allocating”) a machine reserves the machine for the exclusive use of the acquiring process. The machine is no longer available to any other process, including another MAAS instance, or a process such as Juju.
Before deploying a machine, MAAS must acquire it (status ‘Allocated’). When deploying from the web UI, this action is performed automatically (and invisibly).
The action remains useful in terms of reserving a machine for later use. To acquire a machine explicitly select the machine and apply the ‘Acquire’ action.
To acquire/allocate a random node:
To acquire/allocate a specific node:
Deploy
- DHCP server is contacted
- kernel and initrd are received over TFTP
- machine boots
- initrd mounts a Squashfs image ephemerally over HTTP
- cloud-init triggers deployment process
- curtin installation script runs
- Squashfs image (same as above) is placed on disk
The curtin installer uses an image-based method and is now the only installer used by MAAS. Although the older debian-installer method has been removed, curtin continues to support preseed files. For more information about customising machines see Custom machine setup.
Before deploying, you should take two key actions:
- review and possibly set the Ubuntu kernels and the Kernel boot options that will get used by deployed machines.
- ensure any pertinent SSH keys are imported (see SSH keys) to MAAS so it can connect to deployed machines.
To deploy a node:
To deploy with the CLI, the node must have a status of ‘Allocated’. See ‘Acquire a node’ above.
