Datasource Not Found Issue Post Deployment
But in this case we are using only one static IP during deployment from the /27 subnet. I dont think so we are running out of Ip’s
Might be worth to enable a user with
/var/snap/maas/current/preseeds/curtin_userdata
#cloud-config
debconf_selections:
 maas: |
  {{for line in str(curtin_preseed).splitlines()}}
  {{line}}
  {{endfor}}
late_commands:
  00_maas: [wget, '--no-proxy', {{node_disable_pxe_url|escape.json}}, '--post-data', {{node_disable_pxe_data|escape.json}}, '-O', '/dev/null']
  10_adduser: ["curtin", "in-target", "--", "sh", "-c", "adduser --disabled-password --gecos '' maas"]
  20_addpwd: ["curtin", "in-target", "--", "sh", "-c", "echo 'maas:maas' | chpasswd"]
  30_addsudo: ["curtin", "in-target", "--", "sh", "-c", "usermod -aG sudo maas"]
and when you get error you can login into the machine and poke around. In particular I’d check if under /etc/netplan you have the proper configuration
I cant even able to login to the server to check the netplan…i.e No login prompt is available
@troyanov fyi…can u pls look into this and suggest any fix
