- DHCP server is contacted
- kernel and initrd are received over TFTP
- machine boots
- initrd mounts a Squashfs image ephemerally over HTTP
- cloud-init runs built-in and custom commissioning scripts
- machine shuts down
Commissioning requires 60 seconds.
NUMA and SR-IOV
When using these nodes, you can specify a node index for interfaces and physical block devices. MAAS will display the NUMA node index and details, depending upon your configuration, to include the count of NUMA nodes, number of CPU cores, memory, NICs, and node spaces for bonds and block devices. You can also filter machines by CPU cores, memory, subnet, VLAN, fabric, space, storage, and RAID, among others.
Commissioning scripts
Scripts can be selected to run from web UI during commissioning, by testing hardware, or from the command line. Note that MAAS only runs built-in commissioning scripts during enlistment. Custom scripts can be run when you explicitly choose to commission a machine. A typical administrator workflow (with machine states), using customised commissioning scripts, can be represented as:
maas-support-info: MAAS gathers information that helps to identify and characterise the machine for debugging purposes, such as the kernel, versioning of various components, etc. *Runs in parallel with other scripts.
maas-lshw: this script pulls system BIOS and vendor info, and generates user-defined tags for later use. *Runs in parallel with other scripts.
20-maas-01-install-lldpd: this script installs the link layer discovery protocol (LLDP) daemon, which will later capture networking information about the machine. This script provides some extensive logging.
maas-list-modaliases: this script figures out what hardware modules are loaded, providing a way to autorun certain scripts based on which modules are loaded. *Runs in parallel with other scripts.
20-maas-02-dhcp-unconfigured-ifaces: MAAS will want to know all the ways the machine is connected to the network. Only PXE comes online during boot; this script brings all the other networks online so they can be recognised. This script provides extensive logging.
maas-get-fruid-api-data: this script gathers information for the Facebook wedge power type. *Runs in parallel with other scripts.
maas-serial-ports: this script lists what serial ports are available on the machine. *Runs in parallel with other scripts.
40-maas-01-network-interfaces: (MAAS v2.9 only) this script is just used to get the IP address, which can then be associated with a VLAN/subnet.
50-maas-01-commissioning: (MAAS v3.0 and higher) this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, details about attached USB and PCI devices, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
50-maas-01-commissioning: (MAAS v2.9 only) this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
maas-capture-lldp: this script gathers LLDP network information to be presented on the logs page; this data is not used by MAAS at all. *Runs in parallel with other scripts.
maas-kernel-cmdline: this script is used to update the boot devices; it double-checks that the right boot interface is selected.
Commissioning runs the same dozen or so scripts as enlistment, gathering all the same information, but with these caveats:
Commissioning also runs user-supplied commissioning scripts, if present. Be aware that these scripts run as root, so they can execute any system command.
Commissioning runs test scripts which are not run during enlistment.
Commissioning scripts can send BMC configuration data, and can be used to configure BMC data.
The environment variable BMC_CONFIG_PATH is passed to serially run commissioning scripts; these scripts may write BMC power credentials to BMC_CONFIG_PATH in YAML format, where each key is a power parameter. The first script to write BMC_CONFIG_PATH is the only script allowed to configure the BMC, allowing you to override MAAS’ built-in BMC detection. If the script returns 0, that value will be send to MAAS.
All built-in commissioning scripts have been migrated into the database.
maas-run-remote-scripts
is capable of enlisting machines, so enlistmentuser-data
scripts have been removed. -
The metadata endpoints
http://<MAAS>:5240/<latest or 2012-03-01>/
andhttp://<MAAS>:5240/<latest or 2012-03-01>/meta-data/
are now available anonymously for use during enlistment.
enable_ssh
: Optional integer. Controls whether to enable SSH for the commissioning environment using the user’s SSH key(s). ‘1’ == True, ‘0’ == False. Roughly equivalent to the Allow SSH access and prevent machine powering off in the web UI. -
skip_bmc_config
: Optional integer. Controls whether to skip re-configuration of the BMC for IPMI based machines. ‘1’ == True, ‘0’ == False. -
skip_networking
: Optional integer. Controls whether to skip re-configuring the networking on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain network configuration in the web UI. -
skip_storage
: Optional integer. Controls whether to skip re-configuring the storage on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain storage configuration in the web UI. -
commissioning_scripts
: Optional string. A comma separated list of commissioning script names and tags to be run. By default all custom commissioning scripts are run. Built-in commissioning scripts always run. Selectingupdate_firmware
orconfigure_hba
will run firmware updates or configure HBA’s on matching machines. -
testing_scripts
: Optional string. A comma separated list of testing script names and tags to be run. By default all tests taggedcommissioning
will be run. Set tonone
to disable running tests. -
parameters
: Optional string. Scripts selected to run may define their own parameters. These parameters may be passed using the parameter name. Optionally a parameter may have the script name prepended to have that parameter only apply to that specific script.
Commissioning logs
MAAS keeps extensive logs of the commissioning process for each machine. These logs present an extremely detailed, timestamped record of completion and status items from the commissioning process.
Disabling boot methods
It is possible to disable individual boot methods. This must be done via the CLI. When a boot method is disabled MAAS will configure MAAS controlled isc-dhcpd
to not respond to the associated boot architecture code^. External DHCP servers must be configured manually.
To allow different boot methods to be in different states on separate physical networks using the same VLAN ID configuration is done on the subnet in the UI or API. When using the API boot methods to be disabled may be specified using the MAAS internal name or boot architecture code^ in octet or hex form.
For MAAS 3.0 and above, the following boot method changes have been implemented:
- UEFI AMD64 HTTP(00:10) has been re-enabled.
- UEFI ARM64 HTTP(00:13) has been enabled.
- UEFI ARM64 TFTP(00:0B) and UEFI ARM64 HTTP(00:13) will now provide a shim and GRUB signed with the Microsoft boot loader keys.
- grub.cfg for all UEFI platforms has been updated to replace the deprecated
linuxefi
andinitrdefi
commands with the standardlinux
andinitrd
commands. - GRUB debug may now be enabled by enabling rackd debug logging.
Automatic selection
When selecting multiple machines, scripts which declare the for_hardware
field will only run on machines with matching hardware. To automatically run a script when ‘Update firmware’ or ‘Configure HBA’ is selected, you must tag the script with ‘update_firmware’ or ‘configure_hba’.
Similarly, scripts selected by tag on the command line which specify the for_hardware
field will only run on matching hardware.
Interpreting scripts
A script can output its results to a YAML file, and those results will be associated with the hardware type defined within the script. MAAS provides the path for the results file in an environment variable, RESULT_PATH
. Scripts should write YAML to this file before exiting.
The YAML file must represent a dictionary with these two fields:
result
: The completion status of the script. This status can bepassed
,failed
,degraded
, orskipped
. If no status is defined, an exit code of0
indicates a pass while a non-zero value indicates a failure. -
results
: A dictionary of results. The key may map to a results key defined as embedded YAML within the script. The value of each result must be a string or a list of strings.
Optionally, a script may define what results to return in the YAML file in the metadata fields… The results
field should contain a dictionary of dictionaries. The key for each dictionary is a name which is returned by the results YAML. Each dictionary may contain the following two fields:
title
- The title for the result, used in the UI. -
description
- The description of the field used as a tool-tip in the UI.
Here is an example of “degrade detection”:
!/usr/bin/env python3
--- Start MAAS 1.0 script metadata ---
results:
memspeed:
title: Memory Speed
description: Bandwidth speed of memory while performing random read writes
--- End MAAS 1.0 script metadata ---
import os
import yaml
memspeed = some_test()
results = {
'results': {
'memspeed': memspeed,
if memspeed < 100:
if result_path is not None:
Tagging scripts
Debugging scripts
You can individually access the output from both completed and failed scripts.
As long as you’ve added your SSH key to MAAS, you can connect with SSH to the machine’s IP with a username of ubuntu
. Type sudo -i
to get root access.
Testing hardware
Interpreting logs
MAAS logs test results and allows you to view a summary of tests run against a particular machine. You can also example details on any particular tests:
You can also examine the “raw” log output:
Testing networks
Delayed NW config
Once commissioned, you can configure the machine’s network interface(s). Specifically, when a machine’s status is either “Ready” or “Broken”, interfaces can be added/removed, attached to a fabric and linked to a subnet, and provided an IP assignment mode. Tags can also be assigned to specific network interfaces.
