How to read commissioning logs
Commissioning logs provide insights into the commissioning process, detailing script executions with timestamps and outcomes. This page explains how to access these logs.
Introduction to commissioning logs
Commissioning logs document the execution of commissioning scripts, each entry detailing the script name, execution timestamp, and result (e.g., passed, failed). These logs are crucial for troubleshooting and ensuring the successful commissioning of machines within MAAS.
Viewing commissioning logs in the UI
To explore detailed logs for each script, navigate to the “Commissioning” tab of a specific machine. A status table presents all commissioning scripts, their outcomes, and links to detailed logs. Examining these logs offers insights into each script’s function and output.
Retrieving commissioning logs via MAAS CLI
For a direct approach, use the MAAS CLI to fetch verbatim logs of commissioning script executions. This method is ideal for accessing logs of current or past script runs:
To focus on specific results, such as the latest or currently-running scripts, replace $SYSTEM_ID with current-commissioning, current-testing, or current-installation. Further refine the results by script type, name, or run:
Suppressing failed results
To exclude known failures from your analysis, suppress failed results:
Setting $SUPPRESSED to True or False will adjust the visibility of these results in the output.
Downloading commissioning script results
Download script results for offline analysis or documentation purposes:
Use $RUN_ID, identified as id in detailed output, to specify the desired script run for download.
