Running MaaS 2.8.1 (8567-g.c4825ca06) on Ubuntu 20.04 via snap
I have 4 dell blades I am trying to commission.
When there are no nodes in MaaS, PXE booting any node will commission it successfully.
When a single node has been commissioned, any other node PXE boots, but fails to commission.
When commissioning with shutdown disabled, I connect to a node that failed to commission:
Looking at logs, there are no errors.
On the controller, there is no entry for that node under rsyslogs (the successful node has logs).
When trying to manually commission, running
maas-run-remote-scripts --no-download --no-send .
It successfully executes.
I have looked through the scripts, but can’t identify an issue.
EDIT: Trying to commission with, and deploy 18.04. I have tried other versions and have the same issue.
EDIT2: [There was other errors here which have been checked and do not apply] - The first machine to be commissioned (out of any I have), will always commission successfully.
