Availability zones (deb/2.8/UI)
Six questions you may have:
  1. How do I list availability zones?
  2. How do I add an availability zone?
  3. How do I edit an existing availability zone?
  4. How do I delete an existing availability zone?
  5. How do I assign a machine to an availability zone?
  6. How do I allocate a machine in a particular zone?
List availabilty zones
To see a list of availability zones, choose “AZs” from the top menu:
Add a zone
To create a zone, navigate to the ‘AZs’ page of the web UI and use the ‘Add AZ’ button. Enter a name for the zone and click ‘Add AZ’.
Edit a zone
To edit a zone, on the ‘AZs’ page, select a zone and use the ‘Edit’ button:
This selection allows you to change the name and description for the added (or edited) zone:
Delete a zone
To delete a zone, on the ‘AZs’ page, select a zone and use the ‘Delete AZ’ button. Doing so will also move any potential machine associations to the default zone.
Assign a machine to a zone
To assign a machine to a zone, from the ‘Machines’ page, select a machine (or multiple machines) and choose ‘Set zone’ using the ‘Take action’ button:
After selecting a zone hit the ‘Set zone…’ button to apply the change.
You can also edit a machine’s ‘Configuration’ page to change its zone.
