Hello!
I have a http://www.ni.com/sv-se/support/model.crio-9063.html embedded computer which lacks a remote “power on/off” network interface. (Needed for maas to be able to power it on/off)
The computers power is controlled by short-circuting a jumper on the power-supply unit which turns the unit on.
My question is if you know of a means to add a secondary device that will be able to control the circuit. Very much like a simple network attached relay.
(I’m also trying to communicate with the supplyer, but I thought to ask here aswell.)
