About tags and annotations (snap/2.9/UI)
  • VM hosts
  • network interfaces
  • devices
  • nodes (in the CLI only)
Work with tags
This section is devoted to procedures for working with tags. We begin with some general operations that apply to all tag types, such as naming conventions and basic mechanics. We then walk through the various tag types, providing procedures that will help you create, assign, remove, delete, list, view, and filter tags, covering the nuances of each type.
Tags for these different objects have similar purposes, but they aren’t necessarily administered in the same way – so we’ve included detailed sections for each tag type.
Work with tags in general
There are a few general procedures for working with tags, centred around naming conventions and basic mechanics. These procedures apply to nearly all tag types. They will be referenced often in the subsections that follow.
As a general rule, you’ll want to know how to:
Name tags
Create and assign tags
  1. Place the cursor in the “Tags” box, wherever it is located on the screen, and type the name of the new tag:
  1. Hit the return key to add the new tag:
  1. When you’re done, click on the appropriate completion button to complete the operation.
Delete and remove tags
To remove (unassign) a tag:
  1. Find the “Tags” box, wherever it is located on the screen:
  1. Click the “X” next to the tag you wish to remove.
  2. When you’re done, click on the appropriate completion button to complete the operation.
Work with machine and VM tags
Create and assign machine tags to machines
If you want to create a new tag, and simultaneously assign it to a machine, use the following steps:
  1. Go to the machine list and select the machine you’re interested in modifying, by checking the box next to the machine name:
  1. Select the “Take action” drop-down menu and select “Tag”:
  1. Create and/or assign the desired tag, as described in the general tagging procedure above.
  2. Don’t forget to hit the “Tag machine” button when you’re done, to apply your changes to the machine.
Tagging multiple machines at once
In the first step of the above procedure, you can select more than one machine:
Any tags you add in the “Tags” box will be applied to all selected machines, as noted by the change in the “Tag machine” button:
Other than the scope of the transaction (e.g., tagging three machines, in this case), everything else about this operation conforms to the general tag assignment procedure.
Remove and delete machine tags from machines
  1. View a machine’s currently assigned tags: stay on the ‘Machines’ page and click on the machine in question. MAAS will display currently-assigned tags in the Tags pane of the ‘Machine summary’.
  2. Select the ‘Configuration’ tab and then the ‘Edit’ button alongside ‘Machine configuration’ to edit tags:
  3. Follow the general tag removal procedure.
List machine tags for multiple machines
Of course, if you need to do so, you can see a list of all the tags assigned to machines by opening the “tags” section of the filter drop-down. With the UI, you can’t see a list of tags assigned to all virtual machine hosts (VM hosts), or filter VM hosts by tag. It is possible to get a more comprehensive list of machine tags and retrieve a list of VM host tags using the CLI; choose the CLI link from the menu on the top of this page to explore these options.
  1. To list all tags, visit the ‘Machines’ tab and expand the ‘Tags’ subsection in the left pane. In this view, you can use tags as machine search filters.
  2. Select one or several tags. The machines that satisfy all selected tags will display on the right pane. Notice there is a search field at the top of the right pane. You can type a search expression into this field.
  1. On the machine list, select the machine of interest by clicking on its name.
  2. On the machine detail screen that comes up, look for the tags on one of the cards presented there: the tags for that machine should be listed there.
View machine tags for a VM host
  1. Click on the KVM tab at the top of the screen. This will bring you to a list of active KVMs for your system:
  1. On the detail screen that comes up, choose the “Settings” tab at the top:
  1. In the settings tab, you’ll see a box labelled “Tags.” You can use this box to view, assign, edit, or remove tags for the KVM:
Work with controller tags
Create and assign controller tags
  1. Click on the “Controllers” tab to open the controllers page:
  1. Click on the hyperlinked name of the controller to which you want to assign tags. You will see a screen with several cards, like this one:
  1. Find the “Tags” card and click on “Edit.” You will be brought to that controller’s “Configuration” tab.
  2. Click on the “Edit” button for “Controller configuration.”
  1. Follow the general procedure to assign a tag to the controller.
Remove and delete controller tags
  1. Follow the general procedure to remove a tag from the controller.
List controller tags
There is no explicit means of listing tags for all controllers in the MAAS UI; see the in the MAAS CLI to do this, by choosing the CLI link from the menu on the top of this page. If you click on a tag assigned to a controller, though, you will see a filtered list of machines with that matching tag.
View controller tags
  1. Click on the hyperlinked name of the controller of interest… You will see a screen with several cards, like this one:
  1. Find the “Tags” card; this card will list all the tags assigned to this controller.
Work with block device tags
In the parlance of MAAS, a block device is generally an unassigned and unpartitioned physical or virtual disk. This subsection will show you how to:
Create and assign block device tags
  1. Go to the machine list:
  1. Select that machine that has the block-device you want to tag:
  1. Click on the “Storage” tab and focus on the block labelled “Available disks and partitions:”
  1. Click the drop-down arrow at the right end of the row containing the block device you want to tag. Choose the “Edit…” option (the wording may vary, e.g, “Edit physical…”). This will take you to an editing screen for that block device:
  1. Add tags as described in the general procedure.
  2. Be sure to click on the “Save” button when you’re done.
Remove and delete block device tags
  1. Select that machine that has the block-device with the tag you want to remove:
  1. Delete tags by clicking the “X” next to them, as described in the general procedure.
List block device tags
There is no explicit way to list all block device tags in the UI; check the CLI version of this page for a more comprehensive procedure. You can list all storage links, though – block device and partition – by using the filter tool on the machine list. Here’s how:
  1. Select the “Filters” drop-down and open the section titled “Storage tags:”
View block device tags
  1. Select that machine that has the block device that interests you:
  1. Click on the “Storage” tab and check the page for tags:
Work with partition tags
List partition tags
There is no explicit way to list all partition tags in the UI; check the CLI version of this page (via the menu above) for a more comprehensive procedure. You can list all storage links (block device and partition) by using the filter tool on the machine list. Here’s how:
View partition tags
Work with network tags
Create and assign network interface tags
  1. Go to the machine list and select the machine where that interface resides, by clicking on that machine’s name:
  1. Click on the “Network” tab:
  1. Choose the interface you’d like to tag, by selecting the checkbox next to its name:
  1. Select the drop-down under “ACTIONS” at the end of the row, and select “Edit Physical” to edit the parameters of the physical interface:
  1. Edit the “Tags” field as desired, as described in the general tagging procedure above.
  2. Be sure to select the “Tag machine” button to apply your changes to the interface for that machine.
Remove and delete network interface tags
  1. Choose the interface you’d like to un-tag, by selecting the checkbox next to its name:
View network interface tags
  1. Choose the interface you’d like to see, by selecting the checkbox next to its name:
  1. Be sure to cancel the operation when you’re done.
Work with device tags
Create and assign device tags
To add a tag to a device, follow this procedure:
  1. Select the “Devices” tab; it may be in a drop-down labelled “Hardware,” if your browser window is not very large:
  1. Select the device you’d like to tag, by clicking on its name:
  1. In the “Tags” card, select the “Edit” link, or choose the “Configuration” tab under the device name:
  1. Select the “Edit” button on the “Configuration” tab which comes up:
  1. Edit the “Tags” field, as explained in the general tagging procedure above.
  2. Be sure to hit the “Save changes” button to apply your changes to the device.
Remove and delete device tags
To remove a tag from a device, follow this procedure:
  1. Select the device you’d like to un-tag, by clicking on its name:
List device tags
  1. Go to the device list:
  1. Select the “Filters” drop-down and open the section titled “Tags:”
Here you will see a list of all device tags currently assigned to devices in this MAAS.
View device tags
  1. Select the device that has your interest by clicking on its name. A device summary will appear:
The “Tags” card on that screen with show you all the tags currently associated with this device.
Work with annotations
This section will explain how to:
Create and assign static annotations
To create and assign static annotations (a note) to a machine, follow this procedure:
  1. Go to the machine list and click on the machine of interest:
  1. This will bring up a machine summary for that machine:
  1. Select “Configuration” and click the “Edit” button to the right of the “Machine configuration” section:
  1. Add free-form notes in the “Note” field, as desired.
  2. Click “Save changes” to update the machine’s configuration.
Delete static annotations
To delete static annotations (a note) from a machine, follow this procedure:
  1. Edit the free-form notes in the “Note” field, as desired.
View static annotations
To view static annotations, you can follow this procedure:
  1. Go to the machine list and look at the machine of interest; you should see the first few characters of a note in the bottom half of the column marked “POOL/NOTE:”
  1. Click on the machine, which will bring up a machine summary for that machine. Switch to the configuration tab to see the full note:
