This section will answer a few questions:
- What is MAAS?
- What does MAAS offer me?
- Can MAAS co-locate key components to conserve resources?
- How does MAAS work?
What is MAAS?
Tell me about PXE booting
What MAAS offers
MAAS also discovers all of the USB and PCI devices attached to your physical or virtual machines, and allows you to delete them from the machine’s visible configuration, prior to deployment, if you so desire.
MAAS 2.9 does not discover USB and PCI devices. This feature is available from MAAS version 3.0.
<h3 id="heading–ui-smooth-maas-experience’>A smooth system-management experience
- web UI (optimised for mobile devices)
- Ubuntu, CentOS, Windows, and RHEL installation support
- open-source IP address management (IPAM)
- full API/CLI support
- high availability (optional)
- IPv6 support
- inventory of components
- DHCP and DNS for other devices on the network
- DHCP relay integration
- VLAN and fabric support
- NTP for the entire infrastructure
- hardware testing
- composable hardware support
<h3 id="heading–cli-smooth-maas-experience’>A smooth system-management experience
MAAS integrates all the tools you need into a smooth system-management experience. It includes the following eleven features:
- IPv6 support
- hardware testing
Colocation of key components
How MAAS works
The above comment about disk space bears repeating: MAAS will overwrite the disk space of all machines it enlists. All pool machines are under the control of MAAS; you should provision them using other methods.
MAAS users allocate machines for use when needed. The web UI also allows you to allocate machines manually, such as when you are reserving specific hardware for certain users. You can remotely access and customise the installed operating system via SSH.
An allocated MAAS machine is more flexible than a virtual instance in a cloud. You have complete control, including hardware drivers and root access. If you want to upgrade the BIOS, for example, you can allocate a machine to yourself and complete the upgrade. Once you have completed the upgrade, you can send the machine back to the pool.
